Question about Microsoft Windows 98 for PC
98 loading error message
When trying to load win98 after formatting hdd oe exception in vxd error message is coming in blue screen pls help
  • Anonymous May 29, 2008
    fatal exception 0E has occured at 0177:0000001
  • 10,594 Answers
Format HDD in FAT32 file system. Win98 cant be installed on NTFS file system. or use Disk Manager 2000 software to format entire HDD and creat new partitions.
Posted on May 29, 2008
    Sergeant:
  • 336 Answers
When you format something you WILL lose all of the data that was there. I would also recomend upgradeing to XP, 2000, or NT. You may need to reinstall the OS. If you need instructions ask me and I can help.
RCF
I get exception OE at 0028:FF045A63 in VxD called from 0028:C1C77C57 in VxD
It looks like your hardisk or memory problem.. probably there is bad sector.. try to do 'Check Disk' (usually it called 'scandisk') first.
Oct 09, 2011 | Microsoft Windows 98 for PC
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
Fatal exception error on shut down - VXD VWIN32
you need to start in safe mode and remove your video drivers. Hopefully you have a win98 disk to get the drivers off of. Remove drivers and restart, it will then recognise that the drivers are gone let it ask for drivers and let it find them automatically and install them. Then see what happens
Feb 23, 2009 | Dell Computers & Internet
Hard disk failure
Hi, assuming the hdd won't finish a format, it is possible that some sectors are damaged. If you still want to try and use the hdd even with these defects, you can try and partition the hdd. Guesstimate at what point the hdd stops responding and really guess where the defects end. With this info, partition the hdd into 3 with the middle containing the defective sectors. Format only the first and third partitions. For simplicity, Win98 might be easier to work with rather than XP. Hope this be of some help. Do post again and let us know how things turn up.
May 05, 2007 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
MIL-W1897L cannot install device
Not much of a solution, but keep uninstalling and re installing the driver cos win98 not very good for driver issues, i remember having to fiddle around with it with win98se also. Perhaps the device is recognised but not being installed because of a faulty slot or mobo fault. But personally I wouldn't go on-line with win98, would advise upgrading to xp sp2, much better with security and easier to sort out driver issues. Trying to forget Win98/SE, not very pleasant!
Oct 12, 2006 | Milan Technologies ShAir Access MIL-W1897L...
Microsoft Windows 98 for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
