Question about Zebra LP 2844 Thermal Printer
We have two of three of these printers all connected the same way and one consistently but sporadically will not print. We have to disconnect all cables and shut everything down and then plug all back in and it will work for a while. The network cables and connectors have been replaced at both ends and the ports have been changed about and there is no change. The printer has actually been moved to another location and the same thing does not happen.
  • 732 Answers
Clinic211, Will a "known good" 2844 work or will it too "develop" same "no print" hang-up symptom when connected at the same location where original problem occured? How far from the "HUB" is the port that is causing the problem? The ZEBRA corp is 17 to 20 minutes drive from me and located in Vernon Hills Illinois USA. 12fixlouie
Posted on Oct 07, 2010
Wireless printer prints sporadically
Try changing location and or adjust router antenna
Apr 29, 2017 | Samsung ML2955DW - ML-2955DW Wireless Mono...
Computer says unable to communicate with printer : if using firewall unblock UDP port 427..I'm not sure how to do this. This problem occurs sporadically..sometimes the printer works, sometimes it doesn't
Most of the times just skipping that message will let you use the printer. That message is something that has to do with the printer rediscovery just incase the printer get's disconnected.
Checking with your anti virus software provider might help.
Regarding that message though. Try skipping that and try printing.
The printer should work.
Feb 06, 2011 | HP Officejet 6500 Wireless All-in-One...
2170W wireless connection to mac computers
My suggestion would be to connect an ethernet cable from the printer to the router. This is a more stable connection for the printer on the network.
All of your wireless computers will be able to connect to it and print to it as long as they are connected to the network.
To get the printer back in wired mode, you will need to reset the printer and network card of the printer.
1. Turn off power
2. Hold down go Button while switching back on
3. Wait 2 secondes before letting go and press the go button 8 times quickly
4. Wait for the unit to finish warming up
5. Repeat steps 1 and 2
6. Wait 2 secondes before letting go and press the go button 7 times quickly this time
7. Wait for the unit to finish warming up then plug in the ethernet cable.
Mar 28, 2010 | Brother HL-2170W Laser Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
My HP Photomart 8450 prints in black sporadically.
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP Photosmart 8450 InkJet Printer
Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Dec 31, 2008 | Dell 922 All-In-One InkJet Printer
HP Business Inkjet 1200 printer always prints the Alignment Page
Dec 30, 2008 | HP Inkjet 1200dn Printer
Need carriage adjusment. Often, the platen pulls either two or more sheets or none.
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Oct 22, 2008 | HP PSC 500 All-In-One Printer
HP PSC 1410
if the ink on paper is sporadic mostly the black inkjet print catridge only needs replacement.
May 18, 2008 | HP PSC 1410v All-in-One Printer
Reverse printing
Have you found a solution for this problem??   I have the same problem; happens sporadically but once it happens there's no fix.  With the particular page I am printing I can't get it to correct itself. I thought at first it was associated with Classic apps but that wasn't consistent.  I just printed from Safari on a wireless iBook and this page is also reversed.  Extremely frustrating!!!!!
Thanks.
Oct 19, 2007 | Brother MFC-5440CN All-In-One InkJet...
Zebra LP 2844 Thermal Printer Logo
61 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
