Question about Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony recorder rdr-hx750 How to reset to analog.no picture but there is sound on av
My problem is last time i did some thing on dvd but i 4get wat i did and now even the remot dosnt work i have frind he said to me i have to restart but i dont now how i do it pleas help me to find the problem ??thx
Posted on Feb 12, 2011
Sony KDL 32W705B PLUS A CASSETTE RECORDER RDR-VX 420
Evidently you are recording from the TV. You're running the signal to the TV then out of the TV to the recorder. You should run the signal to the recorder then output to the TV.
May 15, 2015 | Sony Televison & Video
TV code number
0056 is the code for the LG TV.
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
IrishDruid
May 13, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I have two SONY RDR-HX750 DVD Recorders that I haven't used for a couple years (I've been using my TOSHIBA and MAGNAVOX DVD Recorders with Hard Disk Drives instead). Now when I try to play a DVD or play a...
have you tried resetting both machines, also if they where stored somewhere cool and then brought into a warmer area it may just be condensation, if this is the case leve the machine to acclimatise for an hour first.
To reset power up and remove all discs, then press and hold the Stop button on the machine and then press the power button, the unit will power off and will be reset to factory default.
Dec 06, 2013 | Sony RDR-HX520 DVD Recorder
Hello, I need to reset SONY RDR-VX515. Thanks
Hello
To reset your RDR do the following
Press the System Menu while the recorder is in stop mode.
Select "Setup" and press enter.
Select "Easy Setup" and press enter.
Select "Start" and pre Enter.
Follow the instructions. OK.
Feb 21, 2011 | Sony RDR-VX515 DVD Recorder/VCR
I have a RDR-VX525. When I record from VHS to
You must be aware of the disc you use for recording. You better used DVD+R for better works. Will you please state, what kind of disc you used? the in put manuals? or you might forget to turn the analog/digital switcher?
Jan 20, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
DVD player/recorder Sony RDR-HX750 error code E01 when selecting HDD. Anything I can do to fix that ?
Hi
You need to re-format the drive or replace the drive and format it.
Search eBay with "Sony formatter" for more.
Jul 03, 2008 | Sony Televison & Video
Recording from VCR to HDD
The VCR tape contains a copy inhibitor along it's length, so cannot be copied. the only way to make a copy is to use a truly analog route, without any copyright checking getting in the way. I think this is mentioned in the manual.
Feb 21, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony RDR-HX725 DVD Recorder/HDD Recorder Logo
583 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
