Question about Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood
When I am taking a shower the pilot lite goes out, also even when I have heat and fire it gets very hot and when I turn it down the fire goes out and also the pilot lite.
    Champion:
  • 248 Answers
Sounds like thermalcouple/heat sensor
Posted on Oct 09, 2010
How do i reignite a worcester 24i combi boiler ?
I looked up this unit for you and found out it is a hot water system. She needs to get to the main gas valve to light the pilot. This unit has what is called a thermocouple on it that keeps the pilot on, even when the boiler shuts down. Its just a matter of lighting the pilot light. There should be a metal plate with the directions on it at the gas valve to lite it. You will have a knob, more then likely red or black in color on top of the valve. It will say on, off, and pilot. It should be in the on position now. Turn it to pilot. Have some matches with you and a flashlight if you can. You will need to look back into the burner area to where your pilot light will be. The thermocouple is a copper colored tubing that runs right back to the pilot, as it has to get hot from the pilot flame to work. To start, depending on how far back you have to reach with the match, you may need to use a piece of solid cardboard rolled up, a small piece to light it and reach in. Turn the knob to pilot. Now, push down on the knob and hold it down. This lets gas get back to the pilot, so you must keep it down and light it at the same time. Once it is lite, you have to hold it down for at least a minute. Slowly release it, very slow. The flame should then stay on. Once it is on, turn the gas knob to on. With the thermostat set to come on, it will fire up and heat the water. If the pilot will not stay lite after you hold it down for 1 minute, and keeps going out, the thermocouple will need to be replaced. It is the copper line that screws into the gas valve and goes back to the pilot. You can get them at any hardware store for around $6.00. Maybe you can help her install it. It is very simple to do. I believe the pilot just blew out and she will need to light it. Just follow what I have told you, and she will get it lite. Good Luck to you.
May 25, 2011 | Bosch Water Heaters
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Water is hot until you adjust the shower temperature to warm from hot, then heat unit shuts off and it is 100% cold. Shower head is low flow so wonder if the flow is below minimum for heater to fire?? Can...
These unit is design to operate at a specific flow rate and cannot be ajusted if you need to have a warm shower you will need to get a bath remote where you can turn down the temp whenever you need without disrupting the flow rate
Jul 21, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Rinnai infinity hot water service, goes hot and cold...not fun in the shower!
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably machanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem,
Oct 20, 2008 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood Logo
151 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
