Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes seem to stick and it is hard to push the dyson 07 along
  • 171 Answers
It sounds like it is sucking it self to the floor. you may need to adjust the height adjustment for the head so it rides a little higher and wont stick to the carpet.
Posted on Oct 07, 2010
I have used my dyson dc39 perhaps a dozen times tops and the brush bar won't stay spinning. I've stood it upright and turned it off, clicked the brush power button. Spins then stop-makes pop sound.
If it's like my DC-07, the brush shouldn't spin if it's upright, and also won't spin if you don't have the clutch for the brush fully engaged. Make sure that the back of the unit is tilted off of the fully upright position, and check that the brush clutch is all the way engaged - there may seem to be a middle setting, but that isn't really where you want to be. Hoping that helps.
Sep 13, 2015 | Dyson Vacuums
After less than 2 years of use why is my DC41so hard to push on bare floors and carpet with the roller brush engaged? My wife will not use it any longer.
Your problem is with the centre wheel. This article will explain everything: http://dysonmedic.co.uk/dyson-dc40-dc41-dc50-hard-to-push-sticking-to-the-floor/
Feb 28, 2015 | Dyson Bagless Upright Vacuum DC41 Animal
I can't push my Dyson Dc33 on my new carpet..it works backwards ok but not pushing forward?
Hi Fran, it's Jack at Dyson.
DC33 is engineered to work effectively on both hard and carpeted flooring. The cleaner head is engineered to adjust automatically for different floor types and carpet piles. You can also turn off the brush bar for hard floors and delicate rugs, using the brush control on the cleaner head.
I'm sorry to hear you're having difficulty pushing your machine forward on this particular type of new carpeting. If your DC33 worked effectively before the new carpeting was fitted, it doesn't sound like there's an issue with the vacuum itself. However, we'd appreciate the opportunity to take some further details about the issue, and may be able to suggest a resolution. You may also want to consider contacting the carpeting manufacturer directly, as they should be able to recommend the best way of caring for this specific carpeting.
When you have your DC33 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 13, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Where is the brush belt on a dyson 07 upright vacuum?
Hi there, it's Jack at Dyson.
The type of belt mechanism will depend on which model of DC07 you own. If you have a DC07 machine without the brush control feature, the user-replaceable belt is located within the cleaner head:
http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if your DC07 includes the brush control feature (you should see the Carpet/Hard floor dial on the cleaner head), your machine will use a clutch mechanism with belts engineered to last for the lifetime of the machine in normal use.
If you have a DC07 with brush control and would like some help with it, please contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Replace dyson 07 animal brush roll assembley
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
Oct 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i fit new brushes in dyson dc 07 have the
you have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
643 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
