Question about Abit AG8 Motherboard
9.0 post code error on Abit an8-ultra main board tried so far: - CMOS reset - replace the button battery - replace vga - replace memory - replace PSU - CMOS rewrite with ROM device - CPU replace
5 Suggested Answers
  • 150 Answers
SOURCE: i can't install windows vista and windows 7
There are lots of compatibility issues with vista and hardware. Please run the vista compatibility program from microsoft.com prior to trying to install. It will tell any and all potential issues
Posted on Aug 30, 2009
SOURCE: I have a MSI MS-6566 Ultra-C v1 with an Intel
have a problem with v1.5 a6566ims always ask if in start setting bios date month and year, and the second when the computer restarted there was no display on the monitor even though I have changed battere, VGA or memory, whether the BIOS has been damaged? what should i do please help. thanks
Posted on Oct 21, 2010
SOURCE: my abit ix38 get 8.7.
i have been having the same sort of problem with my IX38 quad GT and after hours of trying various things i have decided i need to see if the problem is my processor. let me explain...
i have an abit IX38 that i have been running with an E6550 dual core processor. had it for years now with no problems. i recently got a Q9450 quad core from ebay to upgrade, and ran into problems. basically i can't get the **** thing to boot with the Q9450. when i try to boot with the 8pin ATX processor plug, it goes straight to post code 8.3. and shuts off. if i remove the 8pin ATX it will boot to code 8.7. and run for about 15s and then reboot back to 8.7. post code 8.7. is a check CPU voltage issue. code 8.3. says something about saving back to the CMOS stack and the manual says its a psu issue.
i have tried pretty much everything, from changing the psu, to gpu to RAM and more with the same results. so at this point i wanted to get anyone who might have something to say about the situation to comment on if it might be the processor is bad, and i got burned on something from ebay. i do have one last step, and that would be to rule out the mobo (by having my bro install it in his computer which has a Q9450)
any responses would be greatly appreciated.
Posted on Aug 16, 2011
Abit AN8 Ultra
its yuor video card
Dec 24, 2013 | Abit Computers & Internet
I have trouble with my SG-72 board. I clean the CMOS. Now I can't see the screen and there are a long beep and two short beep.
see to it that your VGA card if you have or SOUND card or LAN card is seated properly. Then check also your memory card are seated properly...
good luck
Feb 26, 2011 | Abit SG-72 Motherboard
8.3. 9.0. 4.0. post codes when attempting to boot up.
code 8.3: 12V 4 pin plug disconnected or power supply damage. Check connection /test PSU
code 9.0: OC too high (possible bios damage) clear CMOS as 1st resort
Not sure about 4.0 but 0.4 indicates memory module failure.
Have you overclocked the board? The codes would indicate you went a bit over the top if you did. I'd clear the cmos and check the PSU and reseat the ram and start from the vanilla settings, hopefully the bios chip is not blown
Dec 29, 2010 | Abit Fatal1ty AN8 SLi Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
I hade my fatalaty sitting for like about two months and now that i tried to turn on i get an error 92 it's a an8 sli any suggestion????? thanks in advance
Try replacing your cmos battery with a new one. It should look like the picture:
Hope you find this helpful.
cheers'
Mike
Oct 22, 2009 | Abit Fatal1ty AN8 SLi Motherboard
What is the 'EE' Error code on the board mini display?
From ABIT WEB site:
http://www.abit.com.tw/faq/code.html
E0~EF Boot clock initial programs 00->EF Memory damage 1. Clear CMOS 2. Change memory 3. Send to RMA at last
Now, try to clear CMOS and/or change memory RAM.
Oct 18, 2009 | Abit IT7 Motherboard
Hello. I'm portuguese and i have an abit fatality an8 soket 939 and i have a problem with the motherbord. She stop in the error "9.0" " AWARD BIOS TAKE OVER BOOTING JOB". What i have to do? What are my...
This seems to be a common problem with this board. That error could mean any number of things from a loose cable to a fried chip. Flashing bios will not get rid of the problem.
Take a look at this article.
http://techspotlight.today.com/2009/06/03/abit-motherboard-post-code-error-90/
Good luck,
Hank
Jul 29, 2009 | Abit Fatal1ty AN8 SLi Motherboard
Can this motherboard be saved?
did u replace a different vga card?
Jul 07, 2009 | Computers & Internet
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Abit AG8 Motherboard Logo
515 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
