Question about X2Gen MG19MY 19" LCD Monitor
Monitor area black
My x2gen 19" monitor has a black area on the left side about 4 inches wide. a thin green perpendicular line runs from top to bottom. I am useing two monitors in tandom. the picture is pushed over to the right but does not appear on the second monitor when it runs off the edge on the x2gen.
  • shirley pric May 29, 2008
    I figured out how to make front buttons work and it moved back into place immediately. thanks for info
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Please refer to the solution I just posted on the other problem posted in regard to this monitor.
--- Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer or perhaps through a credit card company, this would be your best recourse. My experience with this type of issue is that the hardware has gone bad. Particular with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
Thankfully you have another monitor, so you are not left with no display device, but I am sure if you are using 2 monitors, there's a good solid reason and need for it. The other problem posted did not indicate that you were using 2 monitors, and so this presents one remote possibility. Try to switch the 2 out - move them between ports. If the "good" monitor continues to be good and the "bad" monitor still displays the same issue, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not, in other words, if you see something go wrong with the good monitor or the bad monitor improves upon the switch, there could be a graphics card/driver issue that we could work on.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa! (Also, I would be very interested to know what does happen when you switch the two monitors... Thanks!)
Posted on May 29, 2008
  • Cheryl Whalen May 29, 2008
    Found the link to the form via which you could file a claim in the bankruptcy proceeding, FYI:
    http://www.x2gen.com/files/Claim.pdf
    Hope this may help, if you can't get reimbursed through some other means.
    smartsolve
    Great!! I am so glad it worked out and you don't have to face the other issues. I would suggest holding onto the information, though, and you might go ahead and file a claim anyway, given that you have lost the value of the warranty included with your purcase...
    Good Luck!
    smartsolve
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
Monitor has four inches of black on left side
did you adjust all the settings on the monitor..?
May 29, 2008 | X2Gen MG19MY 19" LCD Monitor
B&w 6800 lots of horizontal black line areas. also, a vertical white strip about 3/4 inch wide about 3 inches from left side of paper
Hi!
the best thing is to make a copy using the glass and not the document feeder!If there is no lines on the copy simply lift up the cover and on the left side of the glass will be a thin strip of glass,Clean it with a dampened cloth and all line and marks should be gone1
Good Luck!
Apr 02, 2011 | Brother MFC 6800 All-In-One Laser Printer
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
19 inch wide Tftlcd monitor FV926w comes on then goes black
There is power problem in your monitor maybe in the high voltage section. maybe there is capacitor that leaky that cannot hold the power. Need to bring this to the expert technician to fix it
Apr 15, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
X2gen monitor
Hey I've read about your problem cus I had same thing weird lines flying on the screen from one to the other side or crossed and I've found the solution ,there is not enough power strength coming to the monitor power supply because you have to many thong plugged to the same splitter ,just unplug the monitor power supply from this splitter and connect it to another power outlet ,not the same ,another and it should fix the problem at least it fixed my so good luck ,and sorry for my spelling cus I'm Polish ,but I'm trying!
Jan 24, 2008 | X2Gen MG19MY 19" LCD Monitor
22-inch Wide screen X2Gen LCD Monitor
Monitor Help CH000241, No display on the monitor. CH000242, Distorted or skewed image on monitor. CH000243, Monitor has a tint of one color.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Gateway FPD2275W LCD Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
121 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
