Question about Magic Chef MCBR440 Compact Refrigerator
I have an apartment size Magic Chef refrigerator. The freezer works fine but the refrigerator is slowly starting to stop cooling. Now there is condensation forming. Turned dial up but does not seem to be helping.
  • robinhaaland Oct 07, 2010
    My fridge has a seperate top freezer and bottom fridge, but I removed the ice-build up from behind the back of the Vent. Is that correct?
    Thank you...I think that may work!
  • 11,896 Answers
There is a vent between the fridge and freezer. The vent will eventually have ice build up and stop the air flow to the fridge. It will need to be cleaned out thruoughly.
Posted on Oct 07, 2010
  • Nate Stansfield
    Nate Stansfield Oct 07, 2010
    If you remove the farthest rear panel in the freezer, you will see the fan and vent. This vent leads to the fridge vent. The ice buildup is usually in all the venting.
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
The motor on my frostfree fridge never stops running. Below the freezer isnt cooling. The freezer is cold but not freezing
Hi, seen this a few times when i did apartment maintenance,the most likely cause is a bad thermostat.
Mar 06, 2011 | Magic Chef CTB1722 Top Freezer...
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
I have a 13 month old apartment size Magic Chef refrige. It stopped geting cold about 1 month age. I uplugged and it work fine for until now. Same thing. Left it unplugged for a while and now it works...
The fault is very much with the auto defrosting of your fridge. When the firdge stops cooling you are unplugging the fridge to allow it to defrost. As there is so much frost in the cooling coils there will not be any convection of the cool air from the coil as it gets blocked. So after defrost the coils get cleared and works fine till the next time frost appears. So first of all remove the freezer compartment rear covers to access the cooling coils, check for break in wires to thermostat, to the deffrosting heater or open coils in the heaters.Now trace the wires to the defrosting timer which is a 8 hours timer for defrosting the coils by the heaters. You can see if the timer is working. Now one of these could be the culprit but you will have to make sure by testing each one and confirming before replacing. Please do this step by step. Hope you get it right. If not familiar get help. Good day
Aug 03, 2010 | Magic Chef CTB1821AR Top Freezer...
My Magic Chef refrigerator has stopped cooling. When I unplug it for a few days, and then plug it in, it will work for about a week, and then quit cooling again. The freezer is perfect, and continues to...
The most likely cause is that the defrost system is not working. After about a week it builds up with enough frost to stop the cold air from getting to the refrigerator section. The most common problem is the defrost timer, defrost heater or defrost thermostat.
Aug 26, 2009 | Magic Chef CTB1502AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer works, fridge is not cooling
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerant is not circulating well....... please visit your service authority
May 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 04, 2008 | Magic Chef Refrigerators
Magic Chef MCBR440 Compact Refrigerator Logo
400 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
