Question about Recoton Advent Advent HT3251A TV
Advent model HT3251A
32” high definition t.v., model listed above. It was unused for at least a year, and when we energized the set, a light spark developed at the rear right corner of the set. I had opened the cabinet to see what might have happened, surmsing it may have been a fuseable link or something. It is the last component on the right rear of the circuit board assembly. I believe there are two wires going to different parts of the unit, and a line, roughly a ¼” in diameter that goes directly to the tube. There is a little tape band around this component with what looks like a metal retention band, and the sparking appears to be generating from that component. I am trying to identify the component, and see if it is in fact replaceable. Can you help me since I do not possess a schematic? Thanks. no power collector of hot has 50v and when disconnected i have no voltage sounds like power supply but no schematic and dont know what to check
  • richard will Jun 06, 2008
    when i disconnect hot collector should there be 130v at the collector and if not isnt this a power supp problem,because there is only 50-60v once hot collector is disconnected
  • 2,326 Answers
The sparks could be generated due to a loose connection.
I would suggest to try to secure that wire(s) and see if the sparks go away, if they do; you will need to resolder that connection.
Let me know if you need further assistance.
Posted on May 29, 2008
  • Jaime Hernandez May 29, 2008
    The part you are referring to is called flyback transformer. There is a very high voltage going to the tube through that ¼” wire. If the high voltage is leaking from that part, you will have to replace it. The reason you only have 50 volts on your HOT is because the flyback is defective.
    Try to unsolder the B+ voltage line from your flyback and see if that restore the HOT voltage to 130 volts.
  • 4,234 Answers
What is the circuit designation of the part in question? It should be marked on the board as Rxxx or FBxxx. Post that here. That should allow us to identify what it is at the very least.
Dan
Picture lools like hour glass
This sounds like an effect called pincushion. Look under your tv options for an option called pincushion and try adjusting that.
Mar 27, 2011 | Recoton Advent Advent HT3251A TV
No input picture, just a blue screen
Its usually a good idea when asking for parts, to include a model #. Thanks Julio
Aug 01, 2009 | Recoton Advent Advent HT3251A TV
Model ht2751a no power,clicks and power light cuts on and off
I replaced caps in power supply.set work fine now.when off light stay blue,when on light is anber.
Jun 18, 2009 | Recoton Advent Advent HT3251A TV
Advent ht3251a wont turn on
working on same model same symtons,pluged sys into a vareact tv came on normal,problem gone.set works ok when plug into ac outlet.can,t say what cause problem,set work ok now without veriact.will air test three days to see if probem returns.will try freez spay on chips.
Feb 20, 2009 | Recoton Advent Advent HT3251A TV
Ready for nat'l digital transition?
If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
May 23, 2008 | Recoton Advent Advent HT3251A TV
http://www.pwwservicemanuals.com/om/ht27_3251.pdf
there is a user manual that may be helpfull to u.
good luck.
Dec 27, 2007 | Recoton Advent Advent HT3251A TV
Advent HT2751A display no good until after 1-2 hour warmup - maybe
After 3 years, I finally decided to open up the TV and do some troubleshooting. Found out the problem, It was a blown capacitor Location C554 Capacitor value is 2200uF 16V - costs about a dollar to replace yourself and the TV works brand new.
Aug 16, 2007 | Recoton Advent Advent HT3251A TV
ADVENT HT2461A
It seems it's one of those "vintage" sets. I don't imagine that the problem is very major since such (older) sets are known to develop bad joints, especially around the larger components (funny, sounds just like a problem that humans have). It might not be necessary to replace the LOPT. Just resolder as many joints as you can see. Usually the ones reponsible for arcing will leave visible signs of burn. The acrid smell you detected was probably ozone (given off when high voltage ionizes oxygen in the air). Good luck, if you haven't already solved the problem.
Nov 13, 2006 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
83 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
