Question about E-Machines eMachines Desktop PC
How do I open the tower to insert a c d - E-Machines eMachines Desktop PC
  • 573 Answers
Open My Computer and then right click on the CD/DVD drive of your system that are define. For example: "E, or F, or G". Click on eject. or Press on the button CD/DVD-ROM. Mostly it's located in the right sight just below the CD/DVD-ROM "where the CD/DVD can insert". And if this two is not working than take a pin length around 2.5" and push inside the hole it's located in the right sight just below the CD/DVD-ROM. Hope it'll be helpful to you. All the Best!
Posted on Oct 07, 2010
  • E-Machines Master
  • 1,183 Answers
You can use the following user manual to help you do the same
http://downloads.emachines.com/userguides/DesktopPC_UserGuide_en.pdf
If i understand your question, You have a new cd drive that you need to put into the computer. At the back of the computer chassis there are two thumb screws , you need to remove them and remove the side cover to get access to the inside of the computer.
Thanks for using Fixya
Proton
How to insert cd into dell c521 tower
Anonymous,
You can press the button on the front of the cdrom and the cd drawer will open.Insert the cd and then you can then press the button to close.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
#iwork4dell
Oct 14, 2014 | Dell Dimension C521 PC Desktop
How do I open the CD door to insert a disc Dell Intel i7 omniplex 9020
There should be a button located in the lower right of the front panel of the drive.
Aug 07, 2014 | Dell OptiPlex 9020 Intel Core i7-4770...
I am having problems inserting a dvd into my acer laptop tower.I was opened up the side where it says dvd but it doesn't seem to fit in!
A) What is a laptop tower?
B) What is the model number of the Desktop PC?
This can be found on the back, near the Windows product key; or up on the side of the computer tower.
Is it an Acer?
Just pulling your leg about the laptop tower thing. I can see you meant Desktop, and not Laptop.
Just want to make sure you're not referring to an Acer laptop, while posting about a desktop computer made by somebody else.
Post back in a Comment.
I will try to find the User Manual for you, and take a look at this little beastie myself.
Regards,
joecoolvette
(Kicking rubber 'feet'................Hmmm, it's got good tread.
Looking down side of case............no, no bondo.........looks straight.
Yep,...............had oil changes at regular intervals..............there's the 3,000 minute WD-40 sticker...........
................oh, and Computerfax gives it a good report..........
WAIT a minute,..............what were we talking about? !O_O! ]
Mar 03, 2013 | Acer Computers & Internet
The cd door won't open on the tower
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 16, 2013 | ZT Group Cisnet PC Desktop
I have anhp deskjet 3050all-in-one j610seriesi purchased to day my tower won;t open to put soft ware in is there any way to conect to my computer
You mean to say CD reader not opening? Use needle to release shutter lock, insert driver cd in and drivr it for software loading.. check fig for easy understand..any difficulty getback to me..thanks
Feb 04, 2012 | HP Office Equipment & Supplies
How to open a gateway pctower to insert solfware
there are 2 screws at the back of the tower one on the top and one on the bottom place the tower on its side with the side with the connections like usb port and serial port etc; nearest the floor then when you unscrew the screws pull the panel away from the pc towards the back of pc im not familiar with the type of pc but thats how i do it or you might have to push in 2 sockets on either side then when they click pull the panel forward it should slot out hope this helps
Dec 28, 2011 | Gateway Computers & Internet
Hello - I have an acer small tower pc and the dvd slot is along the side and I put in a dvd and it wont come out??? I tried ejecting it from the computer and pressing the button on the tower but it wont...
Typically dvd and cd drives have a very small hole in the front of them.Unplug and discharge your pc then insert a paper clip or something small enough to fit into the hole.This is a manual drive opening over ride.
Apr 17, 2011 | Acer (KV.16X04.007) DVD Drive
I can't open the CD drawer on the tower
This sounds like its jammed. I would suggest getting a knife and yanking it out. It should be fine just make sure you don't snap it.
Simply insert the knife into the middle and slightly tilt and it should spur open.
Hope I helped Dr Reed
Apr 15, 2010 | Dell Dimension 2300 PC Desktop
My monitor does not light up but just clicks
if ur monitor is not coming up... check uplugging the monitor cable from the tower.... if u receive a msg on screen "No input signal" or "No VGA Signal" then Monitor is working fine... if not received monitor is not working properly.
if Monitor working... open the tower and remove memory (RAM) and switch on the pc... u should get beep codes.. if u dint get it.... Motherboard gone bad....else... try inserting RAM in other slot... even then its not lighting up...RAM problem or RAM solt problem..
Aug 20, 2008 | Computers & Internet
HP TOWER
go to:
  • start
  • select run
  • type cmd
  • when dos box opens type
  • sfc/scannow
  • have o/s cd ready if it needs it
  • any damaged files will be replaced
good luck
Terry
Mar 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
E-Machines eMachines Desktop PC Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
