Question about Hyundai ImageQuest HLT-3270 Television
Unable to get remote to respond to up and down on channel or volume
    Master:
  • 473 Answers
Check Battery On the Remote... Check On front Panel TV Look for on off remote also look under menu setup
Posted on Oct 07, 2010
4 Suggested Answers
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Posted on Mar 15, 2010
Testimonial: "Thanks I'll be checking them."
  • 57 Answers
SOURCE: My tv turned on on
check remote first,how to check remote switch on your camera phone point to camera lens,when press any key check screen light glow,you sure r/c ok.next check reciver eye of tv
Posted on Jun 27, 2009
  • 1121 Answers
SOURCE: menu keeps flashing remote control wont work, cant
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Posted on Nov 29, 2009
Just bought an RCL3210 TV. The odd thing is that the Channel up/down key on the remote control does not change the channel. Also, the up/down channel key on the TV itself also does not respond. When you...
You need to find how to CLEAR the auto channel settings. Sounds like the TV is set to SKIP all channels. Look for a MENU and then look for an AUTO setting that will walk through all channels and set those where you have reception as the "list" that the remote and the Up/Down buttons on the tv will choose.
PS: GREAT writeup on your problem and the things you have tried.
May 08, 2017 | RCA Televison & Video
Lost remote to HTC Television....Model number HTV-021TB. The TV is currently stuck on channel search and am unable to make it to anything else......is there a universal brand remote that can replace lost...
No,universal remote only work for the basic like power tv on/off,numbers on the keypad,channel up/down and volume up/down only.Beyond that like inter functions of the tv will not work with the universal tv remote.Only the original remote can do that.Try website like Remotes.com to buy an original remote.
Mar 01, 2011 | Televison & Video
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Nov 18, 2009 | Televison & Video
Unable to find a code for an admiral tv NO.GOJ
Most universal remotes work the same. Try this.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 23, 2009 | RCA 3-Device Universal Remote
My tv turned on on its own and does not respond to the remote, even after replacing the batteries. Furthermore, the volume goes up to 100 and down to zero on its own and the remote is not able to control...
Jun 27, 2009 | LG 32LC7D Television
I was able to program my Comcast remote to control the volume of my tv, but was unable to get it to change channels. Is there something else that I should do?
Controlling the TV power and volume is probably all you'll be able to do with that control. The Comcast remotes are meant to be used with their converter boxes, and normally people want to change channels on the box while the TV stays on the box output channel (usually 3, sometimes 4). The remote's channel up and down buttons and number keypad only send out the codes recognized by the converter box. You'll need to fall back to the TV remote if you want to control more than power and volume.
May 04, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Unable to access menu with remote control
you cannot enter into menu on most universal remote only on off switch,channel change and volume up and down thats the most you can get out of a universal remote.you will need the originald remote.
Mar 04, 2009 | Emerson Televison & Video
Unable to automatically scan for channels. menu button on remote does not work om my 1992 jc penney tv. No buttons on outside of tv except for the basic channel up/down and volume control. Recently...
To make it easy for you - you should have original remote.
Then through the menu look for channel set up then make sure you select cable or antenna then you do autosearch(sometimes called autoprogram).Unless the tuner is defective,you should be able to program withe the original remote.
Jul 19, 2008 | Televison & Video
Hyundai ImageQuest HLT-3270 Television Logo
55 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
