Question about Cobra Radio Communications
I have an old cobra 25.some times it doesnt make any sound, I can tell that is reciving because I can see the needle moving,I change the speaker for a newer one,some times I had to hit it whit my hand in order to star working (make the static noise)
    Genius:
  • 1,274 Answers
Hi,my name is John. Take the cover off, turn the radio over to solder side up, look at the solder joints real close, you might need a magnifying glass. you will need a solder iron to heat up the solder joints, look closely, re-solder it , good luck,my name is John.
Posted on Oct 08, 2010
Cobra 25 soundtracker with nightwatch
plug the external speaker into your PA jack and select the PA switch. If PA works then the audio chip is good. The cobra 29 must have a mic plugged in to get receive audio, You may have a broken wire at the mic connector.
Jun 19, 2014 | Cobra 29 LTD CB Radio
I have a cobra 25 ltd classic that I bought from a CB shop it was fixed to have 50 W .you can see all the changes made on it .I have it hooked up with two wips 4 ft 1000 w fire sticks and a power mike it...
either he over tuned it and burned the radio out this can happen just cause a radio transmits 50 watts dosent mean the circuity can handle it and it will burn the radio because of overload. another factor is if you are running high swrs with that kinda out put you will fry it sounds like its getting hot and radios dont work well when they get hot take it to a tech tell him what was done to the radio and what it is doing. you can test the radio by buying a watt modulation meter it will tell you excacley what the radio is putting out I doubt its transmitting 50 watts that is a single final radio unless he modified the final.good luck.
Jan 15, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
PA speaker quiet
I think this is a double post,, am I right Freddy??? Mechanic
Oct 22, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Older Cobra 25 ltd
did the gauge stop working or the radio. the gauges on older radios fail quite often . you can order replacements
Aug 11, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Transmissions
Likely cause id the audio output circuit, centered on the TA7222AP integrated circuit.
Jul 15, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
I have no reciving in a cobra 29 ltd chrome
Bad switch. It's that simple. The factory switches are crimp together junk. You may be able to use a pair of needle nosed pliers to softly squeeze the case of the switch together to correct the poor contact in side of the switch, but, if it gets a lot of use you may need to replace it altogether. Or try adjusting
Thanks!
Dodgem
http://dodgem250.angelfire.com
Apr 29, 2008 | Cobra 29 LTD CB Radio
Radio Communications Logo
43 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
