Visual basic i m mking project on online examintion.tell me the coding of login form.how we will connect our web pge to our project.and the connectivity through access.
  • Ariel Lothlorien
    Ariel Lothlorien May 11, 2010
    what are your specs what is the server do you have mysql acsess what exact do you want?
    Scholar:
  • 65 Answers
Look at this it should help you if i am guessing right on what you want http://p2p.wrox.com/topic.asp?TOPIC_ID=15044
-Rel
Posted on May 30, 2008
How to run vb
How to Run a Visual Basic Program on a PC By an eHow Contributor
Like C++, C Sharp and Java, Visual Basic (VB) is an object oriented programming language. Recently it was integrated to the Microsoft .NET Framework. The .NET Framework is a software infrastructure that speeds up program development. It is supported by the Microsoft Visual Studio Integrated Development Environment (IDE), Microsoft's chief programming environment, and that of SharpDevelop.
Difficulty: Easy Instructions Things You'll Need:
  • Visual Microsoft Studio and .NET Framework
  1. Launch your Microsoft Visual Studio. It is a "heavy" application so depending on how much RAM you have it may take a few minutes to load.
  2. Click the Project tab on the first screen. Notice two buttons at the bottom of the screen named "New Project" and "Open Project." Since the tutorial assumes that this is your first VB program, click the "New Project" button. If you worked on a project before, its name will appear in an area labeled "Open an Existing Project" with a hyperlink that opens the project.
  3. Select "Windows Application" in the "Visual Basic Projects" folder if you intend to run your end program on a computer running a Microsoft Windows operating system. Focus in the "Name" text box near the bottom. Change the name from the default to something more descriptive such as "MyFirstVBProgram." Leave the Location to the default value to save your project to the "My Documents" folder. Press OK.
  4. Concentrate on the grey square area with the arrays of dots. This is the "form." The pinboard shows where components like buttons and text boxes will be installed to make a complete graphic user interface (GUI). The purpose of the grid is to align the components.
  5. Run your program. Click "Debug" from the menu bar. Click "Start" from the drop down menu. Alternatively, you can press F5 on your keyboard.
  6. Enjoy your first Visual Basic program in its simplest form. It is identical to the form in Step 4 except that the dots are gone. What you are looking at is a stand alone program that exists as an ".exe" file having the same name as your project. You can find it under the MyFirstVBProgram folder by default.
  7. Understand the difference between the two distinct environments of the IDE, the Design Environment and the Debug Environment. You saw the Design Environment in Step 4 of this tutorial. That was the environment where you could design a GUI on the form using your mouse. The Debug Environment takes over during the compilation interval in Step 5. That is where you can insert break points in your source code so that you test the correctness of the program.
Read more: How to Run a Visual Basic Program on a PC ' eHow.com http://www.ehow.com/how_2072757_run-visual-basic-program-pc.html#ixzz17b5EMirN
Dec 09, 2010 | Computers & Internet
Authentication by Face capture by webcam
For you to be able to do this you would need a separate standalone program. Your web application would try to detect if that program is running or installed on your client's computer if it is then your webapplication would send a request to the local application to run the face capture, if not then your webapplication would require the download of the software.
With regard to your local standalone software. you could do that in visual basic. make sure that your standalone code would also be a small webserver.
so what your web application actually does is it sends a request to the localhost or client computer, assuming that the local standalone is present then your webapplication would be able to connect to it through the small webserver. Well, the main point is that the local software would be the control for the webcam and also the means fo communication between it and your web application.
Apr 16, 2010 | Microsoft Visual Basic Professional...
How to create crystal report in asp.net with vb script code
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
Apr 15, 2009 | Computers & Internet
I have a visual basic program in which i have to display the record from access table by using connection of adodc.and then select record from datagrid will display in another form. plz reply as soon as...
hi,  you may visit this site www.kidwaresoftware.com/ and download all free visual basic source codes with tutorials..  One of the source code will solve your problem.    However their paid Visual basic source codes will most powerful.    As I am total deaf and no source to communicate others... I want to share the  payment source codes with tutorials from  www.kidwaresoftware.com/.  Are you ready... If you download the  source codes with tutorials (only Fee for it) I will share with you.    esakkisivaganesh@yahoo.co.in
Apr 08, 2009 | Microsoft Visual Basic Enterprise Edition...
I dont know anything about vb and my teacher has given me big pro
There are many online help sites available especially for Visual Studio. One of my favorites (which happens to be free) is www.planet-source-code.com. Professionals and begginners alike post code they have created for the community. There is a comprehensive search tool to find examples of code that could prove to be helpful to you.
Mar 27, 2009 | Microsoft Visual Basic 6.0 for PC
Problem in creating report
Crystal Reports comes bundles with VB6 and is a good choice fro reports. Regards -- Joe
Jan 29, 2009 | Microsoft Visual Basic 6.0 for PC
Need a banking project on visual basic
Hi, I got one for you. Just follow the link and download.
http://www.1000projects.com/new/vb/major/13.html. This is about banking project. And also have the ppt.
Dec 11, 2008 | Microsoft Visual Basic Professional...
Search code in visual basic
If your rows are being displayed or hidden on the form, the easiest way would be to use a filter on that part of the form. The filter would be based on the button being pushed; each button would invoke a different filter.
Make sure that the filter property of the form is ON.
Dec 01, 2008 | Microsoft Office Standard for PC
Visual Basic
Hi Buddy,
Create 2 buttons for previous and next in a form(say, current_form). take the previous form as 'prev_form' and next form as 'next_form' then
write a code in the previous button command click event as
prev_form.Show()
current_form.Hide()
write a code in the next button command click event as
next_form.Show()
current_form.Hide()
Please let me know if you have any concerns
Sep 02, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
