Question about Peg Perego John Deere Gator HPX Ride on Toy
How do you change the speed from2 to 5 mph i have lost the directions
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Remove the red plastic piece on the shifter switch, there is a screw that holds it in
Posted on Jun 13, 2012
The tranny wont shift up in drive from third at about 40 mph the tranny starts to hesitate stutter. already changed oil filter and speed solonoid
just by your description (detailed) id say it could go a few directions ??4 a cause, one way is the 40 mph is near the speed that overdrive is engaged (42 mph) these do sometimes have problems inside them (gears ) also the stutter you mention is sort of an indication that your torque converter didn't lock up or is locking/.unlocking this is an indication of a immanent torque converter failure , if car was made past 2001 then chances are good it has some kind of transmission control system that could log a fault to help you look for a cause like a faulty speed sensor or something , ck your codes !!
Apr 12, 2016 | Cars & Trucks
Why does my 2001 Mazda 626 lx weave at 60 mph
if the directional control is lost at speed the things to have inspected are steering ball joints, suspension mounts ,wheel alignment and wheel bearings
Jun 27, 2015 | Mazda Cars & Trucks
Can not go over 0.4 MPH - Level 1 Configuration ?
go under the HOOD cover and see the instruction, RUN the software calibration for easy diagnostic and fix it.
God bless you
Jul 07, 2013 | Exercise & Fitness
My 1999 A4 Quattro 2.8 beeps when I accelerate passed 30 mph
You have the speed alarm set for 30 MPH.This is most city street limits.Look at your manual to change or turn off.Not sure where it is,Check the column switch on either directional or wipers it toggles back and forth to select mode.
Feb 22, 2013 | Cars & Trucks
How to change from mph to km per hour?
Hi chris. If you are asking for the conversion factors, here you go:
1.6 km/h = 1 mph
1 km/h = 0.625 mph
so divide the km/h speed by 1.6 to have it in mph
or multiply the mph speed by 1.6 to have it in km/h
Here is a conversion tool you may like http://www.convertunits.com/from/mph/to/kph
and here is another http://www.eforecourt.com/mph_kph_speed_convert.htm
Dec 04, 2010 | Cycling
I was driving and then i had no mph registering and then the D4 started to blink it changes gears and drives fine i just dont have an odometer reading and now he check engine light is on...
speed sensor connector or speed sensor itself. common problem being the connection being lost... it"s located on top of the transmission under the throttle body area and held in with a 10mm bolt.
Sep 11, 2010 | 1995 Honda Accord
The stopping distance d of a car after the brakes are applied varies directly as the square of the speed r. If a car traveling 40 mph car stop in 90ft, how many feet will it take the same car to stop when...
The stopping distance is proportional to square of speed.
that is 90ft proportional to 40^2 mph.
We can write as 90 = X * 40^2. ( X is a constant of proportionality) .
Which implies X = 90 / 1600 = .05625.
Assume S be the distance at which car stops when the speed is 90 mph.
S = X * 90^2. ( since X does not vary as same car is used)
=> S =.05625 * 8100 = 455.625 ft.
Thank you.
Jun 12, 2010 | Bagatrix College Algebra Solved Full...
Seems to be stuck in a programcan't change speeds won't incline.have reset numerous times with no luck.
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Jun 11, 2010 | RTO Image 15.0R Treadmill Walking Belt
Peg Perego John Deere Gator HPX Ride on Toy Logo
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
