I have a 50" Digital Ultravison TV and the Aspect ratio is not correct and says partial zoom when I turn on the tv. Please advise me where and how to correct this problem.
    Master:
  • 473 Answers
Check Cable Connection .. Some TV Wen They Dont Have Signal They Get Black With No Sound ...
Posted on Oct 07, 2010
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
Jvc lt-47em59 picture too large in all aspect modes
Larger as in -- the screen looks fatter. 4:3 stretched to 16:9 or as in Larger as in, screen is longer but thinner? 16:9 / 10 fitting onto ratio 4:3?
Asuming... its the second one -- that ur screen is box 4:3 and the picture is huge 16:9 which is why u need to "zoom out" to get the full picture -- are u sure some idiot didnt mess with the settings and make the tv "zoom in" if it isnt a aspect ratio issue?
... if it is a aspect ratio issue, and ur using 4:3 (small old box televisions) there should be a ratio setting either on ur television OR on ur set top box, that would by defualt with digital tv have wide screen 16:9 -- id suggest finding the settings either on the tv or the set top box or...
just get a bigger tv that supports 16:9 cheap for 50 bucks.
Mar 17, 2014 | JVC Televison & Video
My tv screen is zoomed in how to zoom out
  1. Check the TV to see if it has a ZOOM / WIDE option or control for adjusting the aspect ratio; if so, try setting it toNORMAL .
  2. NOTES:
    • If there is a SCREEN MODE button on the TV remote control, you can press this button until NORMAL is selected.
  3. If using a cable/satellite set-top box, DVD player or digital video recorder, check the device for aspect ratio controls and try selecting a different display option.
Jan 16, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
RCA HDTV
try the aspect button on the remote. it may be labled format or p size or aspect. you might be in zoom mode keep hitting the button until you reach the desired aspect ratio.
Feb 12, 2008 | Televison & Video
Panasonic TV 50 inch plasma
Dear RyanVa21;
Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote.
Please let me know if that did it.
Thanks!
Richard
Nov 08, 2007 | Panasonic TH-50PX75U Plasma HDTV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
