Question about Home
I have replaced the motor in my Broan model 676 bathroom ceiling fan.The previous on worked but was going bad. Now, however, there isn't any electricity coming to the plug in used for this unit. No matter what I plug into it, there's not juice. Everything is installed & screwed into place. The circuit breaker is also fine. Please advise.
    Brigadier General:
  • 3,513 Answers
Did you actually flip the breaker all the way off, or did you just look at it? Sometimes it can be difficult to tell when a breaker has tripped - so it's a good practice to flip it all the way off, and then back on. (Flipping it all the way off resets the breaker and it has to be all the way off, not just in the middle).
Also check if you've got a wire disconnected, or broken. If you've never worked with electricity, I'd suggest calling someone who has. (I'd see if turning the breaker all the way off worked first).
To run down the problem, the switches will have to be pulled out of the gang box, and the wiring checked. It's possible to do this as a DIY project, but you must be very careful. Turn the breaker off first, pull them out, and inspect the wiring. If there is nothing obviously disconnected or broken, then a multimeter will be needed to check voltage on the wires. Again, if you've never done this before, it would be safer to call in an electrician, or maintenance tech.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 07, 2010
Bathroom fan stick and squeals
try hoovering it get the dirt out and some wd40
Mar 21, 2014 | Broan-NuTone Dryers
Our bathroom Nu Tone Model QT-100l fan is sounding loud and Rough. Can I purchase the motor part for this? If so will the motor be attached to the metal housing and I should be able to simply replace the...
The replacement motor is available from several sources online. The best way is to purchase the new motor assembly. All you need to do is remove the blower housing from the ceiling, there are three screws that hold the motor assembly in place. The whole job takes about five minutes. Here are a few sites with the motor.
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0 http://www.cshincorporated.com/product_info.php/manufacturers_id/33/products_id/11272
Aug 22, 2011 | Broan-NuTone QT100L Fan
How do you remove the cover for cleaning?
the cover is just held in place by two spring type hangers. if you pull the cover straight down from the ceiling it should pop down about 2 inches, and then you will need to squeeze the clips to get them to release.
c...
Feb 24, 2011 | Broan-NuTone Broan 110 CFM Premium Bath...
I have replaced the motor in my Broan model 676 bathroom ceiling fan.The previous on worked but was going bad. Now, however, there isn't any electricity coming to the plug in used for this unit. No matter...
Oct 07, 2010 | 1990 Volvo 740
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
I have a thermador bathroom ceiling heater fan. Where can I get a replacement?
Amazon.com: bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
