Question about Brother HL 1230 Laser Printer
I cannot get the printer cartridge out. It looks as if I need to unscrew the top, which I think is incorrect
    Brigadier General:
  • 10,406 Answers
Open the cover-door. Are there any instructions printed on the inside of the door?
You should be able to 'unlock' the cartridge from its mounts,
and then slide it out.
Posted on Oct 07, 2010
Incorrect cartridge
To reset the error code, disconnect the power cable from the back of the printer. Wait for 60 seconds. Then connect everything again.
If that does not work--you may also check with owners guide for cleaning the printer contacts (removing the cartridges). Cleaning often involves using a Q-tip with water to clean the contacts of the printer carriage. Below is a link for the basic owners guide.
http://support.dell.com/support/edocs/systems/962/en/OM/962_English.pdf
Jul 05, 2010 | Dell 962 Photo All-In-One InkJet Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark X3430 Error: Incorrect cartridge
Load new firmware from Lexmark web site for x3430 or it won't accept the new cartridge.
Jun 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printer Cartridge error on the black right cartridge
I had this same problem with an HP 2210 all-in-one. Maybe the solution is similar.
For my printer I needed a torque bit/screwdriver, size T10.
Unplug the printer, be safe, etc.
Looking at the back of the printer:
- Remove the roller insert in the middle by pressing on the two tabs on the sizes and pulling it out
- Unscrew the two torque bits and remove the back panel. Be careful there will be a wire plugged in from the back panel speaker to a circuit board in the bottom-left corner.
- Unplug this cable
- There will be two power cables (one black-and-gray, the other just black) and two white ribbon cables.
- Unplug all these. Be careful unplugging and plugging these in, especially the ribbon cables, they can be bent very easily
- Plug everything back in and reverse these steps to put the printer back together.
- For me, pulling the cables and plugging them back in reset the printer's memory (Note: Date on printer display reset to "Jan 00 00 00:00a") and I was able to use my cartridges to print again (the "incorrect right cartridge" still had 25% ink in it).
Hope this helps.
Mar 29, 2009 | HP PSC 2110 All-In-One InkJet Printer
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
HP2420 Manual
Here's a link to the service manual. Please be aware that the service PIN is incorrect in the manual and the correct is: HP2420 = 10242004, HP2430= 10243004, HP2410= 10241004.
http://www.feedroller.com/Store/Service%20Manual/LaserJet%202410%202420%20and%202430%20SM.pdf
Apr 17, 2008 | HP LaserJet 2420 Printer
Dell AIO 962 printer faulty
The error you are referring to could be related to either the cartridge or the printer, so please perform the steps below to check if the issue lies in the printer or the cartridge.
Power on the printer and open the top cove, the cartridges will align in the middle of the printer, remove both the cartridges form their slots and interchange them, yes put the Black cartridge in the Blue slot and the Color cartridge in the Black slot, then close the top cover of the printer and power off the printer and restart it, at this point of time check if the error message is changed or not if the error message is not changed and till showing the same as “Right cartridge is incorrect” then you can try to update the printer firmware form the Dell support site, here is how you can do it.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers.
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
If the issue is still not fixed after you upgraded the firmware then I believe that you will have to replace it. However if the error message changes to Left cartridge incorrect after you have interchanged the cartridges earlier then try these steps below.
  1. Remove the color cartridge and clean the metal contacts of the cartridge with a dry cloth thoroughly please make sure that you are using a soft dry cloth to clean the metal contacts of the cartridge.
  2. Make sure that the cartridge holder snap which sits on the top of the cartridge is fixed firmly.
  3. Make sure that you are using a Dell branded cartridge and it is not a refilled one cause Dell printers often give error message when you use a refilled cartridge or a cartridge of some other brand.
  4. If the issue is still not resolved replace the color cartridge.
Regards
Malik Khan
Jan 08, 2008 | Dell 962 Photo All-In-One InkJet Printer
"cartridge incorrect" message
Never throw out any receipts!!! A lesson my dear mum taught me a long time ago. You need to pay attention to what the printer is telling you. Incorrect cartridge error message could mean a clogged printhead, most people think they have cleaned properly but did you do it with proper cleaning solution. Was it a refilled cartridge or new one? Are you certain you did not accidentally touch the gold areas (printer points) as this can put oils and dirt or residue on the cartidge. Gently wipe both heads on cartridge very softly with a non perfumed baby wipe! Yes a baby wipe (people laugh at me until they see their printer go again!!!) Now try printing again. You can get rid of error message only when you fix the problem. If nothing helps, try uninstalling the printer and reinstalling with original operating disc. And yes, the printer cartridges can be faulty. Never dispose of your old receipts until you are virtually replacing the next cartridge. I keep all receipts for all costly items in a clear slip folder, or staple to original barcodes of box they came in. Did you try disconnecting usb cables to printer and reconnecting to reset it.
Aug 11, 2007 | Lexmark MFP-X3470 All-In-One InkJet...
Incorrect ink level reading
kiwipom, While ink cartridges look like plastic cups that only hold ink...they are not. The information the printer needs to think it has a "NEW" set of ink cartridges is on the cartridge itself. You must fakeout the printer to believe you are inserting "new lexmark" inks. Printer companies make money from the repeated sale of the ink, not the printer itself. I had an old epson that I would refill I would then have to place pieces of tape on the cartridge turn the printer on, remove the cartridge move the tape to another side of the cartridge turn on again etc. Anyway lexmark may need the same. When the new original cartridges show try them first to get the printer "thinking" correctly. Let me know what happens. Good Luck, Tim
Feb 27, 2007 | Lexmark X7350 All-In-One InkJet Printer
Brother HL 1230 Laser Printer Logo
20 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
