Question about Ecoquest Fresh Air Air Purifier
We replaced the ozone plate and filter but our fresh air is not working. we are not getting the fresh air sent we did when it was new. any ideas?
    President:
  • 670 Answers
Check the plate contacts and wiring. Make sure that the contacts are clean and make a good contact with the wiring. You can clean the contacts with a old toothbrush with some amonia and water solution. Make sure that the contacts themselves make contact with the metal grid on the purification plate. Hope this helps.
Posted on Oct 07, 2010
Fresh air yd-700a e001 error
My unit would display e001 and e003 errors. Cleaning the filter and replacing the ceramic ozone plate did not fix it. Ended up taking the board out and inspecting it. Three capacitors were bad. After replacing, the system is working again.
Nov 01, 2013 | Ecoquest Fresh Air Air Purifier
Ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Jun 14, 2012 | Ecoquest Fresh Air Air Purifier
Can purifer work without the ozone card working
It will operate without a purification plate, as long as you are running in RCI mode or normal mode. If you normally run the purifier with some ozone output, then you will need a purification plate. Hope this helps you.
Feb 21, 2011 | Ecoquest Fresh Air Air Purifier
I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 10, 2010 | Alpine Air XL-15 Air Purifier
Ozone not working
Mar 24, 2010 | Ecoquest Fresh Air Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
The ozone generator quit working. What is the problem and where can I get parts ?
You can pull off the rear filter, pull the ozone plates, defeat the safety interlock, turn the unit on, and place a screw driver (holding the plastic handle) one one of the ozone bars, and try to make an arc between the screwdriver and the other bar.
If you get an arc, the ozone plates are dirty. Clean well with a brush and sudsy ammonia. If no arc, either the hv transformer is bad, the main circuit board is bad, or the ozone control is bad.
There's one other thing you can check: The two wires that connect to the ozone bars can arc to the chassis sometimes. You can inspect the insulation on those wires to make sure it is intact.
May 12, 2009 | Eagle Advantage Alpine Air Purifiers Eagle...
Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Mar 18, 2008 | Ecoquest Living Air Classic Air Purifier
Fresh-air purifier does not geenerate ozone
The fan is bad it should blow the fuse, I believe that the mother board has a problem, or the Display board may have gone bad.
Nov 04, 2007 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
152 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
