Question about Riccar R650
Need to know how to thread it and a manuel - Riccar R650
  • 340 Answers
There's a manual available free from the Riccar website.
http://www.riccar.com/ftp/whitepapers/650-Owners-Manual.pdf
Hope this helps!
Posted on Oct 08, 2010
How do you thread the machine?
Search the internet for a manual:
Manufacturer + Model + the word "Manual"
or search YouTube videos for a machine similar to yours and follow the threading example.
Nov 16, 2015 | Sewing Machines
Upper thread keep breaking
http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_PC_6000_EN_2572.PDF manual is at the above web site
Jan 26, 2014 | Brother PC-6000 Pacesetter
Need beginners manuel for 1541-s Industrial Sewing Machine
Contact your seller or Juki and ask for a threading diagram.
Sep 01, 2012 | Juki Sewing Machines
How to adjust tension on a Juki 1541s machine
If you have loops on the bottom of the seam it's your top tension giving you problems.
Sep 01, 2012 | Sewing Machines
Thread keeps breaking on Singer 2210 model, need help. not sure we have it threaded correctly either. thanks
If you go to the following website and type in 2210 it will take to a page where you can download a manuel for the machine which tells you how to thread it and shows you a picture. That way you will know if you are atleast doing that part correctly. Hopefully that is all it is. Good luck.
http://www.singerco.com/accessories/instruction-manuals
Jan 04, 2012 | Sewing Machines
I have a 1950's era New Home sewing machine. I do not have a manuel. I have had this machine about 35 yrs. I have always had a problem with the tension. Now, apparently, the thread is somehow...
Most common fault threading the machine without the presser foot being in the up position so the thread goes completely between the discs
Aug 27, 2011 | Sewing Machines
I have this machine and need a manuel to go with it. It came with a video, but its a dvd and not a cd and I need a manuel so I can figure out how to thread it. Please let me know how I would go about...
There's a free to download manual on the Singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 1866 and click on search.
On the next page click on free download!
The model number changes to W1866 as the W is for White.
Hope this helps.
Sep 14, 2010 | White Sewing 1866 Mechanical Sewing...
Manuel
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
May 26, 2008 | Janome L-344 Mechanical Sewing Machine
Shark Euro-Pro Sewing Machine
I had the same problem with my Shark Euro Pro 7133. My problem was in threading the upper thread. The manual does not quite explain so I had to figure this out the hard way.
In threading the upper thread . the thread first goes down from the spool througt a groove. When it comes up it must catch a silver lever that moves up and down before moving it down againPlease let me know whether this helps.
Jan 29, 2008 | Sewing Machines
Bobbin Thread won't come through
Thread the machine and the bobbin. Turn the handwheel towards you with your right hand and hold the the top thread in your left hand pulling slightly to the back of the machine. When the needle goes into the needle plate keep turning the handwheel untill the needle picks up the bottom thread and by pulling the top thread you shold be able to pull the botoom thread through the needle plate.
Practise makes perfect.
Regards
Dupina
Dec 11, 2007 | Singer Featherweight II 117
Sewing Machines Logo
116 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
