Question about Garmin nuvi 1300 Car GPS Receiver
Can you charge a nuvi 1300 with usb with computer and how long does the charging take??
I have just got a Nuvi 1300 and have plugged into my computer with the Nuvi switched off. A little icon (showing GPS unit and computer) shows on GBS screen and unit starts to charge. I reckon about 3 hours to fully charge. You have to unplug GPS though to see battery status.
Martin. U.K.
Posted on Dec 25, 2010
SOURCE: how do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Posted on Dec 03, 2008
SOURCE: Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Posted on Aug 12, 2008
sharcnet
  • 2130 Answers
SOURCE: The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Posted on Oct 19, 2009
Testimonial: "Thanks for the information and direction as to what to do next."
SOURCE: When charging the Nuvi 1300 using a wall plug
It doesn't REALLY matter, but it's always best to have anything turned off when you charge it. Hope this helps.
Posted on Mar 19, 2011
Testimonial: "Thanks for the quick answer! "
SOURCE: Can I use my Garmin
I HAD A PROBLEM CHARGING MY 1300 GARMIN. I PUT A SCREW DRIVER BLADE ON THE TWO SIDE CONTACTS OF THE CHARGING CABLE AND TURNED THE BLADE TO SPREAD THE CONTACTS OUT JUST A LITTLE. IT NOW WORKS FINE
Posted on Aug 07, 2011
My outlet in the car is not on when my car is turned off. Can you charge this unit through your usb port on the computer?
Yes..you can charge your unit via computer port....and in some cases with your cell phone charger.
Sep 11, 2011 | Garmin Nuvi 1300 GPS Receiver
Just bought Garmin 1300 series unit. Need to charge batteries. Can I do this by using my computer or do I have to use car battery?
You can charge it with your computer if you wish. It will take about 8 hours with the computer compared to 4 hours with the car charger. To charge it with your computer just connect the satnav to your computer with the mini USB lead. The computer and satnav must be both turned on.
Jun 12, 2011 | Garmin Nuvi 1300 GPS Receiver
Garmin nuvi 1310 will not charge using pc. It will charge on car battery but batt charging symbol does not display.
A couple of things to try: 1) Use a different USB cable. The one you're trying to use my not be working properly. 2) Try the other USB ports. Most computers have more than one, and there may be an issue with the one you're using. Usually, two USB ports are supplied from the same connector inside the computer, so you might have to try all the USB ports. 3) Try charging the GPS on a different computer with both cables.
Most of the time, one of these solutions will solve the problem. Good luck! Please rate my reply, thanks.
May 15, 2011 | Garmin nuvi 1300 Car GPS Receiver
I just bought a garmin nuvi 1300 and cannot get it charged. nothing fits into the gps. please help
your device should have come with 2 cables
- a USB cable which connects from your computer to the back of your Nuvi 1300 GPS
- an automobile power cable which connects from the 12v cigarette socket to the back of your device
both should be able to charge your device.
Mar 28, 2011 | Garmin nuvi 1300 Car GPS Receiver
Do i charge my garmin at home with the power on or off?
You can charge your satnav either on or off with mains or car charger. A full charge takes around 4 hours. You can charge it on your computer which takes around 8 hours by plugging it into the USB port of your computer. When you plug it into your computer it will turn on automatically.
Feb 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
Can I use my Garmin nuvi 1300 while it is charging via USB cable? This will be it's first use.
Dec 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
How to charge a nuvi 1300 GPS
There are 3 ways to charge your Garmin nuvi satnav.
  1. You can use the car charger that should have come with it. Plug the mini USB plug into the satnav and the other end into the cigarette lighter socket of your car. This method takes approx 4 hours.
  2. You can charge it with a mains charger. This doesn't normally come with the satnav but has to be bought separately. Some dealers do throw one in though so it's worth mentioning. This method also takes approx 4 hours
  3. You can charge it with your computer. By connecting it to your computer with the mini USB lead it charges. This method is the slowest taking around 8 hours.
Dec 09, 2010 | GPS
How do I charge the nuvi 1300?
You can charge it from the USB port on your PC/laptop, if you don't have the original wall/car adapter; all you need is a USB to miniUSB (male mini USB B-type) cable which you should find at any electronics store.
May 25, 2010 | Garmin nuvi 1300 Car GPS Receiver
My gps is not turning on. I tried to charge but there is no signal. Can you please help me?
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 12, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin nuvi 1300 Car GPS Receiver Logo
2,558 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
