Question about Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
To copy a video onto a memory stick, i am not sure if i should be connecting the coloured connectors to the video player or the corresponding colour connectors at the front of the TV
    Problem Solver:
  • 7 Answers
Do you have an internal vdieo card taht allows you to capture and what is the prog you are using.?
Posted on May 30, 2008
In what order do wires go in a connector
with a bit of luck the wires in the corresponding part of the connector will be the same colours as the ones you have pulled out Put the connector together and insert the same colour wire in the hole opposite the same coloured wire.
Oct 02, 2014 | Cars & Trucks
Sony kvj21mf1ak
It sounds like either the TV or the device is trying to do S video instead of composite video.
see if you can change the output type of the media player and make sure that the TV input is not set to S Video.
Nov 19, 2013 | Cell Phones
How to connect samsung ps50c55og to sony dav s500 home theatre system
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
Feb 12, 2013 | Audio Players & Recorders
How do I connect my dvd recorder/player to my TV
RCA Plugs from your DVD to tv must correspond to colours, and must go to AV 1 input on the tv and then from your satelite the RCA Cables must go into the corresponded colours on the dvd player :eg. (Yellow to Yellow - Video) (Red to Red - Left Sound) (White to White - Right sound)
May 09, 2011 | Televison & Video
How to download a psp games for free??????????
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 19, 2011 | Sony PlayStation Portable (PSP) Console
How to download from the computer to psp?
3. EXIT USB MODE
Apr 12, 2011 | Sony PlayStation Portable (PSP) Console
How to download games to psp
First you need to download the game that you want. Save it in your PC.Make sure that it will work with the version of firmware that is on your PSP player. Make sure the file ends with PSP.Then, Insert the memory Stick into your PSP player.Connect the PSP player to your computer via the USB cable. Copy the game onto your PSP player making sure to place them under the "PSP", "GAMES" folders on your memory stick. If these folders don't exist on your memory stick you will need to create them.
Hope this will help you out.
Oct 03, 2010 | Video Game Consoles & Games
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Cannot figure out how to connect ps3 to new tv
this depends, can you fit a DVD player into it? if so you need to find a connector that the white, red and black wire connectors fit into then you can plug it into the same slot as the DVD player. otherwise look for 3 ports in your TV with the corresponding colours. hope this helps.
Apr 26, 2010 | Sony Playstation 3 (PS3) Console
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO) Logo
35 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
