Question about Dell Latitude D810 Notebook
I am not getting any sound from the spekers, however I am getting sound through the earphone
    Brigadier General:
  • 10,406 Answers
Plugging-in the earphones physically DISABLES the built-in speakers. Unplug the earphone, to ACTIVATE the built-in speakers. Hopefully, the action of unplugging will move the MECHANICAL contacts -- if that mechanism is broken,
then it's like trying a broken light-switch -- you can flip the switch,
but nothing happens.
Posted on Oct 07, 2010
Sound does not transfer from laptop to earphones when they are plugged in. Tested earphone and test was good. How do I get the sound to come out of the earphones instead of laptop?
I would guess there is a fault with with the earphone jack socket, the soldering to the printed circuit board or perhaps some of the electronic components that might or might not provide attenuation and/or tone correction for the earphones.
Probably be a cheaper cure to use bluetooth.
I use a usb FM transmitter so my sound files can be played on any nearby FM radio.
Dec 03, 2015 | Compaq Computers & Internet
N no sound
Hello
you just start from speaker first. if the speaker is out there will be no sound output from your TV. To confirm this, just plug in an earphone or headphone pin into the headphone or earphone socket , if provided, on the TV. If sound is available through headphone, it means that the sound output section of your TV has no trouble, but the speker is out. Replacing it with same type and number will resolve your problem. If there is no sound fron the earphone too, surely the sound output section inside the circuit board of your TV has the fault.
If so you have to open your TV. Locate the sound output stage, which can be easly locted through following the speaker wires. There will be an Ic [Sound Output Ic], normally screwed onto a metal plate, to radiate heat out when it works. Check for any bad solderings at the legs of that Ic by tuning the printed circuit board upside down. It is very difficult to locate loose solderings. i always do is, resoldering the suspected solder points by applying a little more solder. You also do this first. If it does not help, resolder the Ic out from the circuit board, and go for a same type and number. Replacing it will solve your problem. In some RCA sets, sound section is built out on to another board. Locate it and do the same. OK.
Nov 13, 2010 | RCA F32650 32" TV
Can i connect spekers to tv without any sterio sisteem
Most of the Sony TVs have a sound output less that 4W or so. If you connect an external speaker directly, sthe speaker shoud match both in impedence and watts, to the internal speaker fitted inside the tv, otherwise the audio output ic inside the tv can get damaged.
You can connect the earphone output of the tv, if any provided on your tv, to the aux; input of your stereo. There is no trouble.
Oct 16, 2010 | Sony KV-35V65 TV
I can not listen with the earphones,when i conect in the front part, but I can listen the music in the spekers . Thanks
Connect the head phone in the port and select head phone in sound hardware .If still sound not come then might be your head phone is faulty.
Sep 29, 2010 | Targa Computers & Internet
Speekar problam
check you speker, u can test using multimeter, if no reading or beep sound, change that speker.
Apr 20, 2010 | Nokia 6085 Cellular Phone
No sonud of the speker
have you properly installed d driver?if not try to reinstall the driver.. if it is installed then you can see a speaker emblem on the right bottom of the screen.
May 17, 2009 | Computers & Internet
Creative spekers
SoundCard SoundBlaster Audiby Model SB 0570
Creative CA0106-WATLF
Creative Tech '02 A120070620
Apr 12, 2009 | Creative Labs Sound Blaster Live! 5.1...
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Speaker no sound
In the socket where you plug in the external earphone are bending contacts, which also switch of the speaker when you are using an earphone. Try either putting in the jack and wobbling and twisting it, or tapping the corner with your knuckle.
IN EITHER CASE - BE GENTLE
That will knock of the dirt and the switch will work again
Dec 10, 2008 | HP iPAQ hw6515 Pocket PC
Problem about sound
i am using same configuration with 5.1 creative speaker with good sound. in 5.1 sound system there are 2 seperate jack for left and right speaker. you attach one adopter having 2 in and 1 out point.The jack is 'Y' shaped. that will solve ur problem.
Nov 25, 2007 | Intel D915GAV Motherboard
Dell Latitude D810 Notebook Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
