Question about Sony Playstation 3 (PS3) Console
My PS3 won't start up. I hook everything in and its like when a car won't start. It makes a little "vroom" noise then completely shuts down. What do I do?
  • Sony Master
  • 1,527 Answers
Hello try resetting it, press and hold the standby button on the front of the ps3 you will hear 1 bleep and then 2 short bleeps after the short bleeps release the button it should reset good luck
regards
shaun
Posted on Oct 07, 2010
When pressing on the gas, sometimes I hear a noise like a hot rod taking off. its not a knocking noise but more like a vroom vroom noise. I was told it was the bearings ing the motor.
could be oil pump its self,dode oil pressure go up when throttle is applied,or dose it have a seperate oil chain thats worn,all the best.
Nov 16, 2015 | Cars & Trucks
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
Can it be a fuse why the car won't start
Have you tried replacing earthing cable
Apr 18, 2012 | 1997 Buick Regal
I have a 1994 jeep grand cherokee manufactured in October 1993. The problem I'm having is that the jeep wont start. At first we had no gas, no spark. We checked crankshaft sensor...it's ok, but...
Try this. Lock and unlock the tail gate with the key and see if it will start. The battery must be hooked uo when this procedure is followed. Whenever the battery is disconnected, the security circuit shuts the ignition down.
When you hook up any battery, make certain that you connect the positive battery cable first and negatvie (ground) second.
May 16, 2011 | Jeep Grand Cherokee Cars & Trucks
When the car is started and left to idle, the rpms goes up and down, vroom vroom vroom
This sounds like a vacuum leak, inspect for broken or loose hoses.
Mar 14, 2011 | 1991 Honda Accord
Ok when i turn my car on the rpm is high right at start, after about 5 min it will go to the normal rpm rate. after the car reaches normal temperature it starts vroom, vroom, vroom then it will stop...
I think the throttle positioning sensor is going bad.
It's called a "TPS" you might need to take it to a repair shop because they are adjusted with a voltmeter.
The specifications vary from engine to engine very hard to adjust.
Dec 04, 2010 | 1992 Honda Accord
Starts then i shut it off and then it wont re start like there is no juice but i dont here any clicking or anything everything else turns on but no vroom vroom no clicking just no power to starter is...
OK, if it starts and after you shut it off, it won't restart, then the likely culprit is the connection at the battery is dirty.
The starter needs a lot of power off of the battery to turn over the engine. And, if the connections are dirty, sometimes it will work, and other times it will not.
Try to remove the connections and wire brush them until they look shiny and new. Reconnect, and I think that you'll be pleasantly surprised.
The connection from the battery to the starter is with a thick wire.
The solenoid on the starter is operated by the key switch.
Good luck on this repair.
Nov 05, 2010 | 1993 Jeep Cherokee Country
My ps3 makes a clicking noise when i load a disc
hmmmmm mayby wask the disc be you play and remember to dry CARFULLY
also PS3's and everything els like to be laid down not stading up that helps them alot
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
PS3 with no Power?
it might be the wall plug try a different one
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
