Question about Boss AUDIO SYSTEMS BV7300 Car DVD Player
I have 2002 cwrn vic and i bought boss 7300 i got all speaker wire hooked up..were i hook up battery yellow cord and trouble with making shure im doing this right..
  • 400 Answers
Yellow wire should be hooked to the constant hot wire in your dash. If you check your wires with a multimeter (if you have one), with your key out of the ignition, you will find it....Only one should have voltage when key is in off position.
Posted on Oct 07, 2010
I recently bought a 2006 Buick Terraza CXL. The radio/CD player and speakers worked fine. I put a DVD in the overhead player to see if it worked and it worked with vehicle speakers. I bought a set of
check power wire make shure yellow is in right place this is for your lights if hooked in with orange it shouldnt be orange is a consistant power sorce red is for only when ignition is on blue is for amplifier all darker color speaker wires should be neg lighter pos make shure none r mis matched make shure you do not have you fade left to right wrong same with front to back
Jan 16, 2013 | 2006 Buick Terraza
Installation BOSS 9990 POWER **** IS ON BUT NO SOUND
recheck all wire make sure the yellow wire and red wire is hook up right
Jul 03, 2012 | Boss BV9990 Car Video Player
Im trying to rewire and hook up a boss bv8724 in my 2009life dodge charger. The colors of the wires are not the same except for the red and yellow wires. I connected red to red and yellow to yellow. I...
I recommend you purchase a wiring harness. RCA output should be on the back of the unit (red and white plugs). Remote wire is probably blue running off the back of the unit. You can purchase a harness at www.crutchfield.com it will have the color codes on the packaging and allow you to just "plug" you radio in, once you hook it to the harness of course.
Aug 28, 2011 | Car Audio & Video
I hooked my boss bv8962 up an still got no power what do you think is the problem. i want to know if that red ignition wire got to be hooked up.
yes the red is your power and make sure you have the ground hook up also and the yellow should be your memory why which it should be hook up to a wire that has power all the time
Feb 17, 2011 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
Im trying to hook my stereo in a ord focus 2005 but to many wires any solution please to get conected
Check this wiring for 2005 Ford Focus Car Stereo Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Hope help with this; keep us updated.
Feb 07, 2011 | BOSS AUDIO SYSTEMS BV7320 Car Video Player
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
Boss bv7985
there should be a wire they wanted you to hook to the parking brake as a safety feature so you cant drive and watch tv. but you can just take that wire and ground it to your black ground wire on your radio that should give you your pic
Mar 09, 2009 | Boss AUDIO SYSTEMS BV7985 Car DVD Player
Car cd player installation
Noooo, lol they should all have a seperate location, look at a wiring diagram from your factory speaker harness, or buy an adapter from scosche or something (available at wal-mart for like 7 bucks) to standardize them. And your speaker wire should not be hooked up to the ground EVER.
Black - Ground
Red - 12V
Yellow - Battery
The red and yellow may OCCASIONALLY be required to be at the same place, but i've only had to do this with a vehicle from the 60's.
Jun 03, 2008 | JVC KD-G310 CD Player
Low amp output
Make sure the BOSS isn't in "Protected" mode (Red led lit) and connect the speakers properly (check the connections if they are in "bridged" mode).
Also, make sure you set the cross-over, bass boost setting, bass volume control and the bridge mode according to the speakers you are connecting. Check the input level too.
The BOSS amplifiers are of very poor quality and it can be easily broken. Maybe yours is broken.
Feb 15, 2008 | Jl Audio E2150 Car Audio Amplifier
Boss AUDIO SYSTEMS BV7300 Car DVD Player Logo
108 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
