Question about GE Energy Star WCVH6260F Front Load Washer
My G.E. front load washer was recently moved to a different house. The drum lock bolts were not used and when unloaded from the truck it came out sideways and laid on the lawn and then rolled one complete turn and then set upright. When I got it in the house and hooked up the drum does not spin true, it is very unbalanced and is shaking very badly. What do you think I did to it?
    President:
  • 1,430 Answers
The usual breakage from doing this is a broken strut. Here is a link for this http://appliancehelponline.com/frontloadstrutvideo.html but the rest of the machine really should be looked at by a professional. The counterweight, seal, dispenser, control all could have been damaged. You should replace the struts if they look bent or dislodged, then run it into a spin cycle. Be ready to shut it off if it starts getting off balance. If it spins smooth unlikely any other damage happened. If not have a pro check it out.
Posted on Oct 07, 2010
If a front load washer is being shipped with only 3 shipping bolts ( from korea to USA),would the washer be OK or there could be possible damage to the drum/washer in anyway?
3 bolts will be ok, The drum cannot move and as long as the other 3 bolts are intact and not broken then there won't be any damage to the machine.
May 02, 2017 | Samsung WF431ABPXAA Washer
We have moved to a different city and as adviced we got the drum locked for safety. How can I remove that, its a front load LG washing machine
hi.
the locks on LG machines are normally 2 or 3 long bolts on the rear of the machine screwed into the back of the drum. all you can normally see are the bolt heads, with what may appear to be a plastic washer on them.
hope this helps
May 13, 2011 | Washing Machines
WE recently purchased a front loading Frigidaire washer. I love it except we can't seem to get it level so it doesn't vibrate. It is on a concrete floor and thought the feet were self leveling but that's...
Make sure you have removed all the shipping bolts and straps. Front loaders come with bolts that go thru the back to keep the drum from moving during shipping. If you brought the washer home yourselves you may have left in these shipping bolts. Refer to you installation manual. It will give detailed instructions on how to set up your washer. If bolts are left in place the washer will vibrate and shake excessively and cause major damage if left in for too long.
Feb 03, 2010 | Frigidaire GLTF1670A Front Load Washer
LG front loading washer: recently moved to a new house and laundry room is on the 2nd floor. Re-installed the shipping bolts in the back of the washer that secures the drum prior to moving the washer. But...
Make sure machine is level and all four leveling legs are solidly touching floor at the same time. Make sure leveling leg locking nuts are screwed up to lock legs in place. Check floor for firmness. (try bouncing up and down in front of washer to see if the floor has excessive give.) You may need to re-inforce floor. Wash larger loads. On bulky items, use a lower spin speed. You can re-spin at a higher speed after cycle is complete if you want them spun out better. (some models have a pump and spin only setting, on others, just turn on the power and then only touch the spin speed button to select a 14 minute pump and spin only cycle, then touch the start button.) The only other thing is that the new LG washers use a balance ring now, which makes the machine perform much smoother. (I know because I gave my old LG to my son and replaced it with the newer model, which now runs much quieter, in the exact same location as the old one.)
Jan 13, 2010 | Washing Machines
It seems that the drum is spinning off its axis
When a front load washer does not spin properly, the problem can be caused by failed axle that connects the pulley to the wash drum, or failed shock or (possibly) broken suspension springs.
Remove washer top, inspect the two or four springs holding the washer drum up. The whole drum should be able to "bounce" a little, when you press down on it.
Remove the lower front panel and with a flashlight, inspect the two shock absorbers. Both should attach up to the wash drum, but it is common for them to break, especially if the front load washer has been moved from one house to another without re-installing the lower brackets and the long bolts that secure the drum during the move.
If the springs and shocks are not damaged, with the top removed look down into the rear area. You will see a large pulley with a belt on it. If you see brown/black grease marks all over or obvious problem when you try to turn the pulley, you have found the major problem.
Please get back to me with what you find. OK?
Jan 03, 2010 | Hotpoint WMA58 Front Load Washer
Recently moved and now my washer sounds like it is going to take off!
Hi.
If you hear an high pitched noise or rumble that becomes louder when spinning at speed, then you may have dislodged the drum bearing or broken the drum bearing spider.
The part is located at the back of the drum.
Dec 03, 2009 | LG WM-2277HW Front Load Washer
Does a Maytag Neptune MAH6500WH have retaining bolts or pins that need to be installed before it can be moved?
If you are moving the washer for a long distance move, it is recommended that the shipping bolts be reinstalled to help prevent damage to the drum and suspension mechanism. This would be especially important if you're using a professional moving company, as they won't be able to move/load/unload it without problems.
If the move is relatively short and won't experience alot of aggressive movement, you can likely move the washer without chance of damage - provided you are careful and don't bounce the washer around.
Here's the info from the Maytag website, regarding moving front loading appliances:
If you are moving to a new home and plan to take your front-load washer and dryer pair with you, please call 800-688-9900, and speak to a fabric care expert. Our expert can recommend a Maytag-authorized servicer who will reinstall new shipping bolts to your washer.
New shipping bolts must be reinstalled to avoid internal suspension and structural damage to your washer during transport.
OK, so get your model number handy and give them a call, (you're missing some digits/alphas) you can get an online copy of your owner's manual that will show you the part numbers for the shipping bolts, if you've misplaced them, or give a call to the toll free number for Maytag, and they'll provide you with the part numbers needed so you can order them yourself and likely save some money versus having a service tech some out and do it for you/
1 (800) 344-1274 U.S.
1 (800) 688-2002 Canada
Hope you find this very helpful and best regards!
Aug 18, 2009 | Maytag Neptune Washer
LG WM2277HB drum wobbles when doing larger loads.
You could have a broken strut. However, keep in mind that these units are designed for 16llbs of dry weight for optimal performance.
Nov 27, 2008 | LG WM-2277HW Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
428 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
