Question about Briggs & Stratton Garden
Automatic choke on a 675 series 190cc is not operating properly, please send diagram if possible
  • 93 Answers
SOURCE: BRIGGS/STRATION 675 SERIES, 190CC SELF PROPELLED
Rust on the Flywheel and Magneto wire brush off., Pluged Fuel Filter or Bad Gas.
Posted on Sep 14, 2009
  • 10865 Answers
SOURCE: craftsman 675 series manual
go to sears direct. Enter your model number and download your manual. Joe
Posted on May 23, 2010
SOURCE: my 190cc, no primw, no choke engine stalls after a
Clean the carb bowl out. Check for water in fuel. While the carb is open check the float for obstructions and good volume of flow.
Make sure the float height is within spec. You will need to go the BS website and get this spec with your motors model and serial number. Normally floats are good when they sit level at the point the fuel stops flowing.
Good luck and be careful!
Posted on Jul 22, 2010
  • 64 Answers
SOURCE: my Craftsman 675 190cc starts in full throttle
sounds like the carburetor is a little gummy and when the engine shuts off it goes to full throttle by the govenor for easy starting but is supposed to return to the set 3600 rpm. try spraying carb clean on the carb and wiggle the govenor arm to make sure it move freely
Posted on Feb 23, 2011
rycgl
  • 1545 Answers
SOURCE: where is the carburetor on
The carburetor would be located BEHIND the air filter housing and air inlet tube. The air filter housing should have a removable (by screw or clip) cover.
Posted on Apr 13, 2011
Mototiller, Gear Drive 675 series ,190cc. Cannot find the Primer, Cannot start the engine.
No results found for Mototiller, Gear Drive 675 series ,190cc sorry this is a google search result
Sep 28, 2016 | Garden
Where do you spray carburetor cleaner in 675 series Briggs & stratton engine
Remove the air cleaner cover and the air filter then spray into the filter box.
Jul 14, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Where is primer on craftsman platinum push mower
It may not have one. Some mowers auto choke using spring tension on the choke plate in the carb. They open the choke when the engine speeds up after starting.
Apr 23, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
I have a 675 190cc push lawn mower. How do I( remove the plastic housing to tighten the rear wheels?
There are a few versions of the 675. Can you find the actual model number? It would be something like 37223. Then I can look up a parts diagram and be of more help. If they are wheel covers they just pop off with a small slotted screwdriver.
Aug 25, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
No spark looking for a diagram of the lawnmower
you can always tear the fly wheel off the gap is .20 top dead center before firing on most briggs motors
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Where is the carburetor on the Craftsman 675 Series 190cc 22" cut self-propelled lawn mower?
Apr 13, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
My lawn mower is surging and spark plug is black is this lack of air briggs& stratton . plus runs ok when running out of petrol /????
Are you running it with the choke on? Also if the air filter is dirty it will do that as well. Black plugs means it's getting too much gas and is not getting the proper air to burn properly. Some engines if you rev them up with the handle right as fast as it will go automatically the choke is on.
Sep 01, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
My 190cc, no primw, no choke engine stalls after a
Jul 22, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Garden Logo
280 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
