Question You just recently answer my question when you mean check the power supply explain that to me please. The fan that was originally on the cpu was hooked up through the motherboard n i hooked up the new fan through the power supply. Now when i took off the old fan it would start up and then cut off. But once i hooked the old fan back then it would run fine.
    Problem Solver:
  • 10 Answers
You need a power supply tester get one for 10 and up but always good to have do u also download the hirens bootcd goto 9down.com they have it there !
Posted on May 29, 2008
Cpu temperature when Power supply is connected (notebook HP Probook 5330m)
It almost look like your power supply output voltage is too high as if it lost it's regulation. Have you got any multimeter you can measure this with? Or do you know someone who has the same model HP who could loan you his power supply for a test? Let me know the results.
Mar 08, 2014 | Speed Pc Cpu Vga Hdd Fan Control...
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
After connecting the sata hdd and the radeon hd 4870 graphics card populated all four memory slots I got no vga signal reminder and then the sys fans starts and stop continously. my power supply is a...
you will need to download the driver for the graphic card from the radon web site check the power supply wattage and if it is not at least 500 watts fit a new power supply
talk wit an ait repair shop for answers as you can explain and question as you go
Oct 25, 2017 | ASUS P5K3/P5K (P5K3 DELUXE/WIFI)...
A fan is making a horrible noise
hello
if its the CPU fan is making loud screech noises, its time to replace it
if the power supply fan is making the noise, its time to replace power supply , 5188-2859 is HP part number $25-$40
CPU fan = 5188-3722 HP part number , costs about $40-50
please rate my service with 4 thumbs up
Dec 09, 2010 | HP Pavilion Elite m9510f PC Desktop
Nothing powers up
Check your power supply connections
Sounds like you may have missed the P 4 connection near the CPU socket.
Hope this helps you please rate...
Thank you
Aug 22, 2009 | Biostar K8M800 Micro AM2 Motherboard
Fan runs constantly
i'm not sure what you mean... what fan... if you mean the cpu fan ... it's supposed to run all the time... is it noisy ?
Robert
Jan 11, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
Your solution re motherboard
"voltage regulator module" thats have next to core voltage connector it's supply to cpu
cpu need 2 volt 45 amp and our power supply can produce voltage 12 volt 3 amp so motherboard can produce more amp for cpu . 6 mosfet using for this process it's near by cpu
Apr 11, 2008 | Intel Motherboard
Cpu fan wont come on after new power supply put in
what made you change the power supply to begin with? Most cpu fans run off the motherboard, but the motherboard initially gets all voltages from the Power supply to begin wth. Did you assume that because cpu fan wasn't running to begin with, that the original power supply was bad. Not a bad assumption but one that needed verification before changing out a power supply. So it seems at this point that you have an unverified bad power supply, a possible bad motherboard, and a known good cpu fan. Plus at ths point you really don't know of the new power supply is good yet until you see something electrical run with it.
Feb 27, 2008 | Intel Motherboard
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
