Question about Dell Computers & Internet
I have a dell inspirion 1545 the power light is flashing white and orange and the battery wont charge
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 07, 2010
My laptop will not power on even though it is charged. It is a Dell Inspirion 1545. How can I fix this?
Turn off laptop
pull battery
hold power button for 30 seconds
Put battery in
try restart.
Aug 24, 2014 | Dell Inspiron 15 Laptop
Flashing orange power light
laptop works ok? battery is charging? you have no problem???? do nothing?????
Oct 27, 2013 | Dell Inspiron 1545 Notebook
Dell flashing orange and white
Orange flashing light, then turning to White, indicates a bad Battery.
Regards,
joecoolvette
Aug 01, 2012 | Dell Computers & Internet
Power light flashing white and orange
RAM has nothing to do with power, nor does the hard-drive, in a PC that has no power what-so-ever. FACT people.
The battery doesn't decide if it charges or powers up neither.
All rechargeable batteries only last ****** (a large number) of charge-recharge cycles. They'll all be fecked eventually (couple of years probably).
No power. You may not like and dismiss but, this is what's up:
1. Charger is fecked
2. DC Jack is fecked
3. Power components of the mother board are fecked
All you need is a multimeter to find out which. If its 3 you need a new laptop.
If there is a light, any light. Your charger and DC jack are fine. This proves that power is going through the charger and DC jack and its number 3.
If you've got a warranty, send it back.
Or bring it to someone with experience.
May 31, 2012 | Dell Inspiron 1545 Notebook
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
Probably battery, although that should be orange not red..
Remove battery and try it on AC alone, if that works, it was a damaged battery halting the process
If it does not, check the charger's tightness in the charging port, if sloppy or loose, this will need replacing.
Some Dell's are VERY picky about the charger, if not the exact model specified, they will not charge the battery
If none of the above, remove battery and test with another Dell charger of the same spec, if this also fails to work and you are sure the light is red, you have a problem with the motherboard. Commonly the charger power board fails on these.
Jan 06, 2011 | Dell Inspiron 1545 Notebook
My Inspiron 1545 turns off when I unplug it from adapter, and when plugged in, the power light on front flashes four times orange and one time white repeatedly.
Does the battery for dell inspiron 1545 plug in. It maybe because the battery pack is too hot ,you can turn off the laptop,let the pc notebook and the laptop battery both cooled down.Then try turn on it to see. If still happen to the matter,it must because the wrong turn off did harm to your Inspiron 1545 laptop adapter.
Dec 16, 2010 | Dell Inspiron 1545 Notebook
I have just installed a new battery on my inspiron 1545 laptop and now the power light flashes white then amber.
Before you start using it, leave it charged for few hours while the laptop is off. If the problem persists, remove the battery and boot with only the adaptor. In case, it's ok, then the problem is with the battery, perhaps it has a defect with it. You better get another replacement.
Good luck.
Thanks for using FixYa.
Jul 07, 2010 | Dell Inspiron 1545 Notebook
Ac adapter problem with dell inspiron 1545
TRy to remove the battery, then power the laptop on with only the ac power adapter inserted. if it powers, then your adapter is ok, and insert battery while its on, battery charging should start. otherwise, you could be having a problem with your charging system.
Regards
Apr 19, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Computers & Internet Logo
330 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
