Question about Toshiba Computers & Internet
Why my light on the adapart want stay on when i plug in to my computer
  • 449 Answers
The light on the adapter wont stay on because the power connectors inside the system is been bridged together. if you unplug the adapter from the computer the indicator led will remain on but when you pluged it, it will goes off. the problem is from the computer system and not the pc, you can take it to a pc expert to check it for you because its not advisable for you to open the system so you wont void the warrant y of the product easily.
Posted on Oct 07, 2010
The red light above the chatging plug stays red when I am charging the computer. is it supposed to be this way?
Try removing the battery, hold the start button for 10 seconds, then reinsert the battery.
Feb 07, 2013 | HP Mini 110-1037NR Netbook
I have a 97 Acura RL,engine light stays on even after O2 sensor is disconnected.I've changed out plugs& checked omhs on coils.Did a compression check on cylinders, 50-80.Do have oil on plugs,
To review, the check engine light will stay on until the problem is fixed and the code or codes are erased. And if the O2 sensor is disconnected the light will stay on for sure.
Do you have the trouble codes stored in the computer ?
FYI - the cylinders should have over 100psi of compression.
Sep 16, 2012 | Cars & Trucks
Battery light flashes and nothing else happens
Yes, the socket broken loose could be your trouble and is common as we are not careful when we insert the plug all the time.
Apr 19, 2012 | Computers & Internet
Computer won't come on.
RAM need to change., see wheather any wire short circut.
Dec 09, 2009 | Computers & Internet
When i turn my computer on the power light and
If your computer turns on and your monitor stays in stand by mode, then there is no communication between your video card and the monitor.
You could check if the cable is plugged in correctly or even faulty.
It is also possible that there is a problem with your video card. Maybe physically uninstalling and reinstalling it could solve it.
If none of this helps, then you might want to check a new video card.
Hope this helped.
Nov 17, 2009 | Dell Dimension 2400 PC Desktop
My hppavilion f1503 flat panel lcd monitor screen stay blank
The monitor should be plug and play, and you've already figured out that it's not your computer by plugging into a working monitor.
This is most likely the power inverter board in the monitor - this is common in many monitors. If the power light is blinking on-and-off, or just staying on with no image, that's the problem. There is a slight chance that it could be the light itself, but inverters fail more commonly.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jun 04, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
PC will not power up
Try to reboot your computer with the disk that it came with.=D
Apr 19, 2009 | HP Pavilion a350n PC Desktop
My zen stone stays on a solid green light
Just tried this on a zen stone with speaker and worked. Connect your zen stone to your computer. When the green light is on, use a paper clip and press and hold the reset button (small hole on the headphone jack side). The green light should turn off. Wait a bit and it should start blinking to indicate it is now charging. Note: This reset only worked when I had it connected to the computer.
Hope it works for you too.
Ken
Nov 22, 2008 | Creative Labs ZEN Stone MP3 Player
Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Jul 12, 2008 | Jazz DV-179 Digital Camera
Computers & Internet Logo
16 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
