Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer runs but does not heat, checked red reset switch but it did not click when I pushed it. Still has no heat. I vaccumed all lint out of all areas that I could see, no help. How do I get heating element out and where is it and the thermostat? How much do they cost?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems to be the Thermal fuse that has gone bad. The thermal fuse is mounted to the exhaust duct inside the back cover panel. When this fuse goes bad it should be replaced as it cannot be repaired. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 07, 2010
I have a whirlpool lgr5634a gas dryer, it heats up but does not seem to heat as high as it should.
possible of lint build up in the discharge vent vaccum/clean out first. next ensure the filter trap is clean and the below area is in the discharge area is cleaned out. also the sensor on the inside of the drum could be coated with sooftner causing the sensor that automaticly tells the dryer when top stop/ amount of heat to produce could be coated use isopropel alchol to clean and check after 10 minutes if the dyer is functioning properly at this time.
Mar 05, 2011 | Whirlpool LGR5634L Gas Dryer
Kenmore he3 dryer check lint screen flashes and dryer wont start. Yes checked lint screen
Hi
Try unplugging it or turning off the power at the breaker panel. This should reset the controls.
Weather this works or not, make sure that the whole dryer vent is clear. often we find a clog in the flexible line, or where the duct exits the house. also there are situations where the clogged duct caused a lint plug inside the dryer. Assuming you can reset the controls, you can run the dryer for a minute with the hose unhooked to see if you are venting the right amount of air.
OR
It is possible the heating element has gone out or one of the thermal disk has blown its fuse. If you turn the dryer on holding the button that is depressed when the door is closed so that the dryer will run you should be able to see if the heating element is getting hot because it should show as a red glow. If this is not happening then most more than likely the heating element has gone out. Most of the time they are fairly easy to replace.
OR
a simple thing is that When the lights are flashing, it is an error code, which indicates a problem with the door switch. Could be a loose connection there.
Thanks for contacting fixya.com
Nov 20, 2009 | Kenmore Washing Machines
The dryer is heating but clothes aren't drying. There isn't much lint on the filter and the inside door and lint area is damp with wet lint spread around that area. It is a MDE5500AY model. Serial...
This just happened to us a couple of weeks ago, and we called a repair man. I might be able to save you $45 for a service call. In our dryer, the lint can fall out of the lint screen and clog up in the back of the dryer. Remove the back of the dryer (you might have to unscrew the lint screen too) and the ductwork inside the back (it's quite easy, I've now done it since my daughter dropped my sunglasses down the lint screen hole) just keep an eye on your screws. Remove the trapped lint, and vaccum out the hose, making sure there's no kinks in the hose as it runs to your house exhaust. Put the dryer back together and see if it works. If not, you've got a fan problem and will need a repairman. But apparently this is the most common dryer problem and will take about 20 minutes of your time to straighten out.
Nov 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer runs fine, but there is no heat. I
You will find the heating elements on the driers are very robust. Normally what happens is there is either a build up of lint which has possibly blocked the air inlet grid,.or possibly being to close to the wall. This in turn restricts cooling airflow .There is a thermal protection thermostat which will activate and open circuit if temperature is exceeded at any time.Need to locate the thermostat and if lucky, you could simply press a button and it will reset. If not, you may need to replace that defective one. Typically the thermostat is at the back and close to the element.
Sep 28, 2009 | Whirlpool LER5636P Electric Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Fisher and Paykel dryer not drying
I've had this problem for 3+ years. There are possibly multiple reasons why your dryer trips the reset switch. My dryer has a design issue with the lint trap, in that it allows lint to build up around what I assume is the heat sensor / thermal switch. It's simple, the temperature is detected as too high in the dryer and trips the switch which cuts power to the heating element. The reset switch access as mentioned in other posts requires either tipping the dryer back or removing the front panel, at least partially, to access the switch. After the reset switch is pushed, you'll need to check if there's lint built up that's causing the reset issue. First, find the reset switch.
To access the switch, there are 4 Phillips head screws that need to be removed. For the first 2, lift the dryer lid and you'll see two half-moon shaped rubber inserts at each of the front corners of the machine. The inserts can be pulled out with your fingers or use a screwdriver, gently. There is 1 screw under each insert that needs to be removed. Once those screws are out, you can put the lid down and lift the plastic top of the dryer that the lid normally rests on. It's attached on the back of the dryer so don't worry, it won't come off...it will lift just like the dryer lid. Be careful of the sharp sheet metal edges. Now there are 2 smaller screws, 1 at each front corner, that attach the sheet metal pieces. Remove each of those screws. To get the front off requires a bit of finesse. You'll see that the front sheet metal panel of the dryer has bends in it to attach it to the sides of the dryer. Gently pull at the top corners, one at a time, to separate the front panel from the rest of the dryer. You'll see that there are u-shaped orange or red plastic pieces inserted into the sheet metal sides that align with holes in the front panel to hold the skin of the dryer together...the front should just pull away from those u-shaped pieces. There is a wire with a clip attached to the bottom of the front panel, probably a ground wire...if it pulls off when you remove the front panel, just reattach it when you put everything back together. The front sheet metal is also integral to the front feet of the dryer, so tilt the top of the front panel toward you and lift. The front panel should pull away. When you put the front back on the dryer, do it feet first by aligning the plastic foot pieces, then align the u-shaped side pieces, then worry about the top corners wrapping back around so the front fits flush.
The reset switch is in front at the bottom right of center and is probably orange. Just push it and you'll hear it click. I would vacuum out the lower part of the dryer at the point, but it's probably not what's causing your problem. I've gotten to the point where I use a yard stick or vacuum extension to push the switch without completely removing the front panel. Then I don't have to detach / reattach the ground wire. You'll see after you do it 3 or 4 times!
Now check to see if lint build up is causing your thermal switch to trip. Pull out the lint trap and you'll see 1 Phillips head screw behind where the lint trap normally sits. Remove the screw, and you'll feel the circular plastic piece the lint trap sits in become loose...pull this round piece out of the dryer from the bottom. If there is a lot of lint behind this circular plastic piece, that's probably what's tripping the heat sensor. Vac it out. Gently feel around the circumference of where you removed the piece to see if the fine mesh lint screen has any holes (if it does, it may be blowing lint into your exhaust and eventually clog the vent to the outside). If the mesh is torn, I assume that larger circular piece needs to be replaced at some point in whole or part. From what I can see, the design of the lint filter and trap is ....****. The system allows lint to enter the area where the heat sensor sits.
The short term fix is to vac out the sensor area regularly and that will keep the switch from tripping, if that is your actual problem. I believe F&P is aware of this issue and will probably remedy it for you. I called them once when this issue originally happened and had to wait for a tech to come out do what I described above. I haven't called them since, but have seen other posts regarding a new part or parts that F&P will provide...hopefully free! Good luck!
Apr 09, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
