Question about Kenmore Refrigerators
I have a Kenmore Elite model #596 76573600. it's a stainless steel side by side with freezer on bottom. it's 4 years old and over the past month it's leaking water from the bottom. it happened 3 times and i don't know where it is leaking from. i don't have the ice maker hooked up so its not that. anyone have an idea?
  • 218 Answers
SOURCE: error message on fridge "er ff"
Error code Er FF indicates that the evaporator fan has failed, or at least is not sending a signal to the electronic controls. Open the door and see if the evaporator fan is running inside the freezer compartment. If that fan stops, then no cold air will be sent to the refrigerator compartment and it will warm up. Possible causes include bad motor, bad connection, bad electronics.
Posted on Jul 25, 2008
  • 1462 Answers
SOURCE: kenmore elite bottom freezer 596 serires
+4 degC for fridge and -18degC for free3zer
Posted on Sep 07, 2008
SOURCE: water leaking into bottom of
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Posted on Sep 15, 2008
WCAnderson
  • 9 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Unfortunately, this is one of the inherent problems with a self defrosting freezer units. Some frost free models/brands are less smelly than others. Grabbing the cubes as soon as they drop so they don't sit in that nasty freezer air and placing them in a zip lock would help a lot but probably not completely. Be sure and clean the inside of the freezer often so there is less of the smell left in the plastic that surrounds the ice cubes as well as the foods. Don't eat freezer burned vanilla ice cream, for sure! Hope this helps.
Posted on Oct 11, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I opened freezer on my Kenmore elite model #596 73503203 and everything was melting, ice had started to turn to water. The refrigerator is only 7 years old, is it worth fixing? The freezer does not seem...
It could need refrigerant...I'd try to possibly get a quote on that.
BUT FIRST,
I'd ensure the coils were cleaned of all dust and dirt...either by vacuum or blow it with compressed air.
I'd also check to make sure the light goes out when the door is closed. Sounds crazy but I had a bad switch once that allowed the bulb to stay on constantly...makes everything warm.
Jul 17, 2011 | Kenmore 73503 Stainless Steel Bottom...
I have a Kenmore Elite Model 106.57863801 side by side stainless steel fridge. The doors squeak when opening and closing. How can I remedy this?
Good day,
Spraying a good lubricant on the hinge pins should solve your problem. Sprays like WD-40 shouldn't be used because they may come in contact with your food.
I suggest you call around to your local appliance parts houses to see which one's carry a "food compatable" spray.
It's safe to use around food and can be saved for future use. Most service techs I know carry it with them in the service truck to use when needed.
Oct 05, 2010 | Kenmore 73503 Stainless Steel Bottom...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Frig and freezer not cooling
it is possible that a start relay has gone bad but more likely is that the compressor has seized up. if the unit is under 5 years old most likely the comp will be under warranty from sears. peyton
Jan 19, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmore elite 77573600
one of the switches are bad if you have a multimeter check them for resistance
Dec 12, 2008 | Kenmore 73503 Stainless Steel Bottom...
Freezer problem (icing behind cover inside of freezer)
Several things to check. Refrigerator needs to be put in manual defrost mode, then check defrost heater and defrost thermostat.
Jun 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
