Question about Datamax DMX-I-4212 Label Printer
How to print image directly on datamax printer with c# using printer language?
  • 20 Answers
SOURCE: datamax printer
More info required.
Posted on Aug 29, 2007
Nic61
  • 1073 Answers
SOURCE: s there any free software for running Datamax E 4203 Printer? it is meant for printing library barcode labels.
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Posted on Apr 24, 2009
bartech9
  • 155 Answers
SOURCE: vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Posted on Jun 10, 2009
bartech9
  • 155 Answers
SOURCE: HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
  • 5 Answers
SOURCE: We use the Datamax Printer to print labels with
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Posted on Aug 21, 2010
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
Zpl emulation with datamax i-4208
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
Image files won't print only name no image
I can help you with this. Please let me know what method you are using to send images (software, dmxconfig, dpl..) and also the type of image (bitmap,jpeg, pcx,etc..). With Datamax printers, 4 types of image can be used: bitmap,pcx,img, and 7bit datamax image file. Another thing to know is that the image must be a black & white, monochrome image. You can use a program like microsoft photo editor to make this change. You can use DmxConfig, Utilities.exe, & DPL (datamax programming language) to load image to printer. Let me know the answers to my above questions to proceed with solution.
Dec 16, 2008 | Datamax DMX-I-4212 Label Printer
Improving bar code image DPI for a darker output
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
Jun 12, 2008 | Datamax DMX I-4206 Printer
Datamax DMX-I-4212 Label Printer Logo
903 people viewed this question
Top Datamax Office Equipment & Supplies Experts
pkwc
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
