Question about Nikon D80 Digital Camera with 18-135mm Lens
All exposures on my camera are fine until i use program priority -aperture priority and shutter priority on these programs exosures come out dark
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
Check exposure compensation setting, set to "0"
Posted on Jul 23, 2013
Bogdan
  • 198 Answers
SOURCE: Blue tint when shooting aperture priority
Hello, First of all let's explain what aperture priority does in terms of electronics and mechanical/optical changes in the way the camera takes photos. Unlike most point and shot digital cameras, your one has variable aperture range. Aperture is related to your camera lens. Their main function will be to collect light and direct it to the camera's sensor. The aperture of a lens is the diameter of the lens opening and is usually controlled by an iris.The larger the diameter of the aperture, the more light reaches the image sensor. Aperture is expressed as "F-stop", for example F2.8 or f/2.8. The smaller the F-stop number (or f/value) the larger the lens opening (aperture). This means that when you're using aperture priority or large aperture values (a smaller f/value) your image sensor (ccd or cmos) will tend to receive more light or slightly overexpose itself. Most simple digital cameras, the point and shot ones, have a fixed aperture, the lens are fixed and that's set to a so believed "optimum" range in order to produce best pictures when using automatic settings. SLR or semi SLR digital camera's woun't achieve best performances when using them on automatic settings, they aren't designed in the same way as the simple camera's. These camera's will tend to either overexpose, or have lighting/colour problems or achieve blurry images when using automatic settings. Any SLR or semi SLR camera user will be required to understand the way photography (electronic photography) works in order to achieve the best performances with it's camera. For your example, I guess the shots have a blue tint on them when you're using natural sun light in your photos, or in room pictures are illuminated by natural sun light. This is the first sign of overexpure, and the best way to reduce it and it's efects is to manually set the aperture range. Note that higher values will reduce the light that passes to the sensor, so you will want to experiment a little with those in order to achieve the best performance. When you take photos in light environments, bright sunny days or in rooms that contain many white surfaces or walls (these reflect the light pretty much and can overexpose the camera even if it doesn't look that bright when you look at them with your own eyes) you may want to use larger aperture value in order to have little light come to the sensor. Look for the highest values in aperture (in your menu) for example F8 or F16. If the pictures come out to dark or miss some details, you may want to use larger apertures (smaller numbers). Try these tests in order to check if your camera's problem can be solved this way. If not please reply back and we will look on the hardware - firmware side of the problem. Regarding aperture a quick recap :) A large aperture allows more light to reach the sensor. It's good when taking portret pictures and also achieves that nice blurry background surrounding your main subject in the picture. It's defined by smaller numbers (for example F1.8 or F1.2 or smaller). A small aperture allows little light to reach the sensor. It's good to take pictures in bright sun light. It's defined by larger numers (for example F16 or F22 or larger). Hope this helps, Bogdan.
Posted on Jul 01, 2007
randy320sgi
  • 121 Answers
SOURCE: aperture priority malfunction
davidsucklin,
You can use the film lens with the D80, but it it not react to the same settings as it did with the film body, the multiplier factor for the focal length is going to be different and it may be stopped down a bit. When you are shooting in aperture mode are you adjusting your shutter and ISO? The camera and the lens have to be communicating the same info to one another inorder for it to work. First set the camera back to auto mode the check the shot to see the settings (f-stop, shutter speed) test them with different ISO's to see what the camera thinks the settings should be, then go back to manual on the camera and lens and try the shutter priority mode with the aperture ring set at the 2.8 to see if it works then change to Aperture mode with the same settings that can take the picture. If it doesn't work keep in mind som of the older D lenses will drop some functionality (like aperture) in certain configurations. You can verfify compatibilty of your specific lens on Nikon's support site.
randy320sgi
Posted on Jan 29, 2009
fikretunalir
  • 238 Answers
SOURCE: Nikon D3000. Exposure lock with focus problem.
Probably your lens causes this I think. Please check these.
1. Your lens may cause this. Change it and try again.If you do not have another lens then go on to check the next instrutions.
2. Check your lens AF button. It should be switched to AF.
3. Turn off and on the camera and try again.
4. Check your battery charging.
5. Your lens should be cleaned complitely. Please check its clearity.
I think it will work. But if it does not work properly again then your camera should be checked.
Clean your camera mirror. For this:
1. Turn off your camera.
2. Remove your lens.
3. Clean your mirror without using water or any other liquid or any other chemicals. Use only special cleaning liquid that is made for lens cleaning.
4. If it does not work then your camera body should be checked electronically and mechanically. This check can only be done with an authorized service tecnician. So you should send your camera to your service dealer.
Posted on May 03, 2010
  • 11967 Answers
SOURCE: My Nikon D70 is not
How low/high do you have the ISO set?
Posted on Aug 02, 2010
Obertelli
  • 3006 Answers
SOURCE: In P S A mode
Have you accidentally left exposure compensation set to underexpose your shots? The fact that the fault only occurs in those modes certainly suggests it.
To return the camera to its default settings is really easy: look at the top right of the camera (as viewed from behind). look for the two buttons with green dots beside them, they'll be the +/- and AF buttons.Press them both at the same down and hold until the LCD panel blinks and then release the buttons. Note that the reset only affects camera settings; it does not format the memory card or delete your images.
If this doesn't work then you have a camera fault and it then needs to go to an authorised Nikon Service Centre.
Posted on Sep 23, 2010
I'm doing a project for school and i need to change the aperture for different photos. But my camera refuses to take the photo on any other aperture. Why is there an aperture adjuster if you can't use it....
It depends on the lens.
If you're using a lens with an aperture ring, simply set the exposure mode to Manual or Aperture priority and change the aperture by turning the aperture ring on the lens. In Aperture priority the camera will set the shutter speed appropriately, in Manual you have to determine the appropriate shutter speed. If you want to use such a lens in Shutter priority or one of the Program modes, you must set the aperture to its smallest setting (largest f/number) and lock it.
If you're using a lens without an aperture ring then it's a bit harder. You can only use the camera in Shutter priority or one of the Program modes. You turn the command dial on the camera to change the exposure, and the aperture will change. If you want to use an exposure different than what the meter suggests, you can adjust it by using either exposure compensation or changing the ISO setting (or both).
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n6006af/nikon_n6006af.htm
Mar 08, 2011 | Nikon N6006 35mm SLR Camera
Tip
How does aperture setting affect a photograph?
The aperture is the opening in the lens through which light passes to the image sensor. Changing the aperture setting allows you to control the depth of field of a photograph. When the aperture is opened to a widersetting, (indicated by a lower f-stop number) more light is passed to the imagesensor, creating more shallow depth of field. Closing the aperture (indicatedby a higher f-stop number) allows less light to pass to the image sensor,creating wider depth of field.
NOTE: The aperture setting is one of three primary settings usedto control the overall exposure of a photograph. The other two primary settingsare ISO and shutter speed. Because the three settings work together to produce the overall exposure for a photograph, changingthe aperture setting will require complimentary changes to either the ISO or shutter speed to produce a properly exposed photograph. These changes will bemade automatically by the camera in the Auto, Program, Aperture-priority andShutter-priority modes.
There are two ways tocontrol the aperture setting on the camera:
  • Aperture-priority mode (A) - When shooting in Aperture priority mode (A), you set the aperture value and the camera automatically sets the optimum shutter speed for you.
  • Manual mode (M) - When shooting in Manual mode (M), you control both aperture and shutter speed, which gives you maximum creative control to achieve the exact results you want.
on Jan 08, 2011 | Cameras
What type of exposure system does it have?
The N2000 has Program, Program Hi, Aperture-priority, and Manual exposure modes, with exposure lock and exposure compensation capabilities. It can TTL auto and manual with flash. The meter is full-aperture and center-weighted.
The Program mode sets both the shutter speed and aperture for optimum exposure. You can adjust the exposure if you want to emphasize shutter speed or aperture. The Program Hi mode tries to set a higher shutter speed for action and/or long lenses.
You can download a copy of the manual here if you want to know more about this camera.
Feb 14, 2011 | Nikon N2000 35mm SLR Camera
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
How do i read a light meter on a Nikon N55? i see the f stop but i dont see the shuter speed, how do i adjust and how do i know its right?
Your camera is either fully automatic or fully manual. In addition it has shutter priority and aperture priority semi-automatic functions. With shutter prior. you pick the shutter speed you prefer and the camera will adjust the aperture. With Aperture prior it works the other way around. The exposure will be always the optimum (decided by the camera program).
You can adjust these automatics with the program dial.
Oct 28, 2009 | Nikon N55 35mm Film Camera
I cannot find my manual and would like to know what the MASP settings are for. Last night I was at a good site to help;however, I cannot find it again. I have a P80. also how do I set the camera to get...
http://support.nikontech.com/app/answers/detail/a_id/13948
P (Program): Camera sets shutter speed and aperture, but allow you to change to another equivalent exposure (Program Shift).
S (Shutter Priority): You set the shutter speed, the camera selects appropriate aperture.
A (Aperture Priority): You set the aperture, the camera selects appropriate shutter speed.
M (Manual): You set the shutter speed and the aperture.
Sep 28, 2008 | Nikon Cameras
Flash exposure does not work in Av and Tv mode
There is nothing wrong here - the camera computes the exposure as the flash is not firing. The flash will fire and it will adapt the power to the received light. You must go into M ot AV, fix your parameters and shoot. The flash will adapt to your whishes - only take care to not choose a shooting time to small (1/200 or 1/60 - you have settings for it).
This is not a bug, but a feature.
Aug 09, 2008 | Canon EOS 40D Digital Camera
Aperture priority, shutter priority
You might try overriding the white balance by setting it for fluorescent. Those bulbs are the usual cause of the green hue
Feb 12, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Aperture priority not working...HELP!!
Hey Mike, This is an easy one. With the battery grip attached, you can only have either Shutter Priority or Aperture Priority work properly. You can change it with the custom function settings of the camera. So you can change it to work with Aperture Priority if you use that more so then shutter priority won't work. Brandon
Oct 21, 2006 | Nikon F100 35mm SLR Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
23 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
