Question about Bugaboo Cameleon Stroller
Can I replace all the foam on the bugaboo cameleon. Handle and near the foot placement on the frame.
  • 419 Answers
You can purchase a replacement handle bar foam from www.bugaboo.com but you will need to purchase a replacement seat frame for the other part.
Hope this helps.
Posted on Oct 13, 2010
  • Stephen Faulkner
    Stephen Faulkner Nov 03, 2010
    In New Zealand we have a company called Para Rubber that sell all things rubber like bungs and tubing. They sell neoprene tubing thats a perfect match. Recovering the carry bar is easy and looks superb, but not the rest unless you take it apart (not easy).
My bugaboo cameleon frame wont click on the chassis
The chassis must be fully opened out and the handle locked in position before the seat / bassinet frame can lock down on to it. The seat / bassinet frame is the safety lock keeping the frame ridged. You should see a square hole (made by two half squares from adjoining hub disks) at the top of the chassis hub assembly when fully open. A square pin under the seat frame must engage into it and the white release button must click. Your Bugaboo will not br safe unless this happens and you should contact the seller to help.macnutz_36.jpgmacnutz_35.jpg
Jul 10, 2011 | Bugaboo Cameleon - Tailored Fabric...
I have a bugaboo cameleon 1st generation that has a fault. If i was to buy a new 2nd edition chassis would my carrycot still fix on to this chassis.
I have a second hand chameleon and it feels like the frame is a little loose. Is there any way that you could tighten the frame up?
May 10, 2011 | Bugaboo 'Cameleon' Stroller
My frame is crooked. how to fix?
Crooked? Bugaboo frames are very strong and it would take considerably force to bend any of the frame members. The Handle Lock and the Handle extension lever lock are another matter all together. They do fail making the frame loose and bendy. I have given detailed instruction on their repair in other posts. Click on my name and you'll find out lot's about your Bugaboo.
Nov 26, 2010 | Bugaboo Cameleon Jogger
My Bugaboo Frog has a split in the foam on the handlebar. Can this foam be replaced, if so where can I get it in the UK. Thanks, Jane.
The foam is a product called neoprene tubing and can be found at specialist rubber product suppliers. Google a local supplier. Changing the grab bar rubber is easy just use hot soapy water but the handle bar is a problem as the foam is fitted before assembly and it would require disassembly to replace. This is not easy as the handle is riveted on and has internal parts to operate the handle locks. You can buy a special glue for repairing wetsuits to fix the split and stop it opening up further.
Nov 13, 2010 | Bugaboo Cameleon Jogger
How to change foam on handles
See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website.
And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
http://www.ehow.com/how_6730072_change-bike-grips.
html Bike grips and stroller handles work the same way.
I just used this post on e-how to replace my maclaren triumph foam handles.
Works like a charm - and it's sooo easy!! :)
Sep 26, 2010 | Bugaboo Cameleon - Tailored Fabric...
Will a frog seat frame fit on a cameleon chassis
Yes it will fit. the fabric seats are not interchangeable but everything else is. Currently I have Cam wheels on my frog chassis. As well as a cameleon canopy, and a fabric flease set on my frog seat.
Apr 20, 2010 | Bugaboo Cameleon Stroller
Where or/and how I add the umbrella into my Bugaboo Cameleon?
Hi
The parasol fits onto the foam surround that you attach the seat/carrycot fabric onto, unless you have the two clip parasol which can be attached to the handle.
Hope this helps.
Mar 22, 2010 | Bugaboo Cameleon Jogger
How do i place the seat on the bugaboo cameleon?
Are you talking about the seat fabric and putting it onto the frame?
Remove the handle bar and the metal pole from the seat frame legs to relaxe frame, put seat fabric ontop top of seat frame and fit. place one strap onto the pins at side with holes then turn seat frame onto side. use foot and weight to bring the other strap over the pins and slot into holes fasten buckle undernethe and the velco tabs.
Jun 05, 2009 | Bugaboo Cameleon Jogger
I don't know how to convert my bugaboo cameleon from a basinette to a seat. I appear to have the necessary fabric but not the straps. It is currently a basinette and I understood it would convert easily....
You should not have to purchase any new parts. Your seat fabric should slide onto the frame, the tether straps toward the foot of the seat should have a metal ring that go onto the hook on either side of the frame and snap with a lobster clasp behind the foot rest.
Aug 11, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
768 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
