Question about APW Wyott AT-Express Conveyor Toaster
Conveyor on toaster won't shut off when you turn the switches off we've had it six months
    New Friend:
  • 4 Answers
The switches are bad
Posted on Oct 16, 2013
2 Suggested Answers
SOURCE: have a apw wyott conveyor toaster, conveyor randomly stops
I had a similar problem I changed the Rear Bearings in the belt & Check the Fan motor in the rear which houses the conveyer Motor wheather it is working or not it could be the fan not working and over heating the motor the last thing is the screws that hold the conveyer motor are too tight as the motor is self adjusting.
Posted on Feb 05, 2009
Conveyor is squealing as soon as toaster heats up. How can I fix it
you cant,somethings you have to deal with if you put anything on it,it will burn off and get on the toast,you could try a drop of peanut oil on each link,but,nothing more
Jul 11, 2015 | Holman QCS2-500 Conveyor Toaster
My toaster doesn't give enough heat to use it
follow this test with multimeter, and fix it. God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord.. If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Nov 08, 2013 | Hatco Conveyor / Toaster
Heat is low
please make this test with the multimeter.God bless you
the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the power cord If the oven doesn't work on its toaster and oven functions, test the main switch As needed, check the fuse .
If the toaster oven stays on when the door is opened, check the main switch (). If the oven doesn't heat, test the heating elements.
I was in military school back in the 1970's , and we had conveyor toaster ovens , and was wondering where i could get my hands on one .
Hello bretrett. These are commercial toasters, often requiring a 220 volt outlet. They are common items, available new or used from most any kitchen supply store. Check in the yellow pages. Joe
Apr 15, 2011 | Holman QCS2-500 Conveyor Toaster
I have a APW WYOTT XPRESS CONVEYOR TOASTER several years old. When I plug it in and hit the one switch, there is a short in the unit that causes the GFI to blow immediately. Could the problem be in the...
i just had the same problem, it was the power switch, i re routed wiring to bypass bagel switch and it works fine, but you will want to replace those switches as they a junkily made and the heat destraoys them every couple years
Aug 10, 2010 | Holman QCS2-500 Conveyor Toaster
Have a apw wyott conveyor toaster, conveyor randomly stops
Jan 17, 2009 | APW Wyott AT-Express Conveyor Toaster
APW Wyott AT-Express Conveyor Toaster Logo
93 people viewed this question
Top APW Wyott Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an APW Wyott Kitchen Appliances - Other Expert? Answer questions, earn points and help others
