Question about Akai LCT3201AD 32 in. LCD Television
Locate capacitor for akai lct3201ad - Akai LCT3201AD 32 in. LCD Television
  • kdbonhamee
    kdbonhamee Oct 07, 2010
    are you looking for where to buy a capacitor, or where it is located on the board
  • 11,361 Answers
Which caps on whcih board? What is the problem with the TV?
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Oct 07, 2010
SOURCE: akai lct3201ad parts for sale
What's your asking price?
Posted on Sep 15, 2008
  • 2318 Answers
SOURCE: akai lct3201AD
It depends what model of power supply you have. They are easy to spot when they are defective, you should see them bulging on top or bottom.
What is the part number or model of power supply you have?
Let me know if you need further assistance.
Posted on Oct 12, 2008
  • 4234 Answers
SOURCE: Tryiny to put my Akai LCT3201AD TV on the wall
For a set this size, there should be at least 4 mounting holes for a wall bracket. Please note that wall mounting is an option so the holes may be covered by plastic caps to hide the holes. These holes should be in a box shape around 1 foot wide or so.
Dan
Posted on Apr 10, 2009
tlm931
  • 273 Answers
SOURCE: Akai LCT3201AD won't turn on. Plugged in and
you have a power supply problem there are caps in the power supply that fail the will be bulged on the top these have to be replaced in most cases or a fast switching diode
or get a replacment power supply and exchange it
Posted on Oct 25, 2009
  • 100 Answers
SOURCE: Where can I find directions on how to replace the
hi, to replace the capacitors need to take the board out, by removing the screws and disconnecting the wires braids. You need bread, tin and absorbs tin. You should take the tin from the legs of the capacitors, until it can release the capacitors outside the board. Next, you put the new capacitors in place. Should pay attention to put the capacitors, by proper polarity of plus or minus. It is important to be precise with the value of capacity and try to put a capacitor with a value of slightly higher voltage, temperature resistant to 105 degrees.
Posted on Mar 15, 2011
Testimonial: "Thanks. Will see if my husband can fix it with these instructions. Can't find anyone in our area to do the work. Many thanks!"
Where can I find directions on how to replace the capacitors in the Akai LCT3201AD. I can order the parts, just need to know how to do it. Thanks!
Mar 15, 2011 | Akai LCT3201AD 32 in. LCD Television
Looking to download free owners manual for AKAI model LCT3201AD
http://www.retrevo.com/support/Akai-LCT3201AD-TVs-manual/id/741ci156/t/2/
click "download the manual" and on the next page you have to enter the funny looking number at the bottom of page and click "download now" and it should begin.
Jul 30, 2010 | Akai LCT3201AD 32 in. LCD Television
Need power supply board for akai model lct32d do not know if same as lct3201ad ?
You can have more than one manufacturer of power supply for the same TV model, best thing to do is to actually get the printed numbers from the actual power supply to match it correctly.
Here are the parts for LCT3201AD, see if it looks right: http://www.shopjimmy.com/catalogsearch/result/index/?q=Akai+LCT3201AD+&limit=200
LT32D is not listed.
Dec 24, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Jan 10, 2009 | Akai LCT3201AD 32 in. LCD Television
Need a stand and remote control for Akai LCT3201AD
Please check this Weblink as they might help you to provide desired parts for you Akai LCD TV.
Jul 27, 2008 | Akai LCT3201AD 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
596 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
