Question about Recoton Advent Advent Calypso Main / Stereo Speaker
Lost woofer in one cabinet.
Recently, the woofer in my left bookshelf speaker stopped working. The tweeter, (one in each cabinet) still work. When I switched the woofer in question with the right speaker's woofer, I discovered that it works. Is it possible that the 2-way crossover in the left cabinet is the problem?
I don't know which particular crossover (specs) to replace it with. The speakers are Advent Baby II  bookshelf speakers.
Thanks in advance,
Donagh
  • Donagh May 29, 2008
    No fuse, and the connections are soldered. There really isn't much to the speakers.
  • 4,234 Answers
I'm not familiar with your specific model, but some of these have fuses for the woofers. Check for a blown safety fuse. Also, verify that the connections to the crossover board are in good shape. These crossovers are not that complex and don't usually fail. Keep us posted on what you find.
Dan
Posted on May 29, 2008
  • ABRsvcs May 29, 2008
    The crossover should consist of a coil and a cap or two. It is possible that one of the caps has failed. Try measuring across the cap with an ohm meter. This should show a moving resistance value. Reversing the leads should show the value decreasing and then rising again. If that is the case, the caps are good. Without seeing the whole system, I can't suggest anything else, just check the wires etc for possible shorts when the speaker itself is placed into the cabinet.
    Dan
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Tip
Choosing Bookshelf Speakers
If you are shopping for a quality pair of stereo speakers for music listening not only should you trust your ears but have a look at the individual components that makeup the speaker. The cabinet of the speaker should always be solid, knock on it with your knuckles and see how it resonates the sound. Preferable it will sound dead and solid; we want the drivers moving not the cabinet!
The tweeter: The tweeter is responsible for the upper range and should be made from a rigid yet light material that does not deform when moving quickly, aluminum, titanium and ceramic are excellent. Paper, silk, cloth and plastic are not good for replicating notes in this range.
The woofer, much like the tweeter the woofer must be made from a rigid light material. Yet the woofer reacts differently since it produces a lower frequency range. Paper aka pulp fiber and other fiber composites work very well, as does aluminum and to a lesser extent plastic.
on Jan 22, 2010 | Audio Players & Recorders
Polk Tweeter on RT 1000i
it sounds like its the cross over
Mar 25, 2013 | Polk Audio RT1000I Speaker
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
Mackie SRM 450, the main speaker has stopped working but the tweeter is OK, there is nothing coming from the speaker at all, no hiss, or clicks.
It could be 2 things:
*Blown Speaker or,
*Fried power amp output stage of woofer, since this speaker operates as a bi-amplified system it has separate amps for woofer/tweeter...
Aug 17, 2011 | Mackie SRM-450 System
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from partsexpress.com
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
Bose 301 speaker fell off bookshelf. Still works,
http://cgi.ebay.com/Bose-301-Series-II-Speaker-Woofer-Pair-Excellent-Cond_W0QQitemZ250402833131QQcmdZViewItemQQptZVintage_Electronics_R2?hash=item250402833131&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Determine the series from the label on the back and get yourself one or a pair (preferred, so they match sonically) of new woofers and replace the broken one. Carefully observe the + and - leads and replicate them on the replacements.
Sometimes you can snag a pair of whole speakers cheaply, too. Then you might end up with one spare 301 and one for parts. I use a single 301 IV as my Rear Surround, suspended on the wall behind my seating position. They also do well as Center speakers. The Series IV is also made of some kind of plastic composite which is bullet-prrof compared to the previous particle board models. I had one hit the floor from 5 feet up and it doesn't have a scratch. Get familiar with the models as they are all different in their tweeter arrangements. For example, the IV's are designed for corner placement with one tweeter facing inward at 45 degrees and one on the opposite diagonal corner of the box facing 180 degrees opposite the front tweeter, into the corner for a bank shot.
http://cgi.ebay.com/Bose-301-Series-IV-Speakers-NR_W0QQitemZ310134927077QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item310134927077&_trksid=p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Mar 15, 2009 | Bose 901 EQ1915 Home Equalizer
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Recoton Advent Advent Calypso Main / Stereo Speaker Logo
266 people viewed this question
Top Recoton Advent Audio Players & Recorders Experts
Ron Rak
Ron Rak
Level 1 Expert
NOEL
NOEL
Tom Chichester
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
