Question about Toshiba QOSMIO F15-AV201 Notebook
Power LED Flashing Yellow on Qosmio laptop F15
My laptop power button is off and power led display is flashing yellow. The laptop doesn't work. I appreciate your assistance. Thanks.
  • thetranspota Nov 03, 2008
    absolutely not power at all
  • Mark Williams
    Mark Williams May 11, 2010
    Have you tried removing the cable to power supply, removing battery, press power button, re-install battery, reconnect power supply, power up normally?
    Novelist:
  • 77 Answers
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
Posted on Jun 08, 2008
  • Dana Stienheimer
    Dana Stienheimer Jun 08, 2008
    CLARIFICATION:
    with your laptop, there are two possibilities.
    This flashing LED usually means only two things, both are quite harmless:
    1. Some laptops will flash the power LED when battery is charging. If
    this is the case, it should stop when battery is fully charged. This
    can be presumed if the laptop starts normally while LED flashes. If
    not, suspect step 2 below:
    2. Your
    seconds.
    If
    laptop normally.
    If
    good luck.
QOSMIO G30 no start up only flashing DC-IN LED
Rebouldin resoldering the video proccesor this is the problem or change the main bord a new !
Feb 06, 2014 | Toshiba Computers & Internet
Toshiba Qosmio G30 Flashing DC- In LED on power up and cannot start laptop
I found some G30 with defective memory and it cause boot up problem. You can try to remove one memory to test it. Testing the laptop with a good working memory is the best way.
Feb 06, 2014 | Toshiba Qosmio G30-166 Laptop AC Power...
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Jul 01, 2012 | Dell Precision Workstation 470 (204816690)...
Hi, I have a pronto m51. The yellow led in the
If it's the yellow battery light it will blink when the battery voltage is very low, too low to drive and lower than the red blink.
May 10, 2010 | Invacare Supply Group Invacare Pronto M51...
Main power button LED is flashing or solid yellow
This is a major problem that crippled Dell. Moels Optiplex Gx260, Gx 280, and Dimensions of whose mdel number i don't remember have this problems. This signal shows that either a power supply or your motherboard is malfunctioning. If you have an insurance better use it now or else get some technical assistance.
Nov 03, 2009 | Dell Dimension 8200 PC Desktop
Toshiba power led flashing yellow
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Powerbutton flashing yellow
If the main power button LED is flashing or solid yellow, this could indicate a hardware problem.
Was it running good before?
Are the diagnostic LED lights all green?
Here is what dell says:
If the power light is blinking amber  —
 The computer is receiving electrical power, but an internal power problem might exist.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Do you remember what the BSOD said?
Oct 22, 2007 | Dell OptiPlex GX620 PC Desktop
Packard Bell Imedia 1402 wont boot up
you did not install the new Hdd properly, the part of the ribbon cable with colour should be by the side of the power connector and the power connector should be connected with the red cble by the side of the colour on the ribbon cable.
uzowuanya
e-mail:uzowuanya@yahoo.ca
Oct 03, 2007 | Computers & Internet
Toshiba QOSMIO F15-AV201 Notebook Logo
462 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
