Question about KitchenAid Refrigerators
5 years ago my wine fridge kuws246eblo. leaked some brown goo then stopped working. a tech replaces the thermostat. 5 years latter the same brown goo has appeared and has stopped working. Is this a common problem? I would like to save the tech charge and replace myself if this is the issue
SOURCE: Fridge not working
Fridge not working,regulator is under repair.can u suggest the services in hyderabad.
Posted on Feb 18, 2008
SOURCE: Wine cooler
Thermostat again.
Posted on Jun 26, 2008
SOURCE: Sub-Zero 511 Freon Leak
Paul, we have the same problem with a built-in Kitchenaid and the price of replacing the fridge is out of sight for us. Where did you get the equipment to check the freon and replace it?
Posted on Jul 22, 2008
  • 117 Answers
SOURCE: Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Posted on Jul 28, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
Why does My marvel 61WCM wine fridge turn on but right away off again?
First make sure it is not plugged into an extension cord. Low voltage could cause this type of problem. If you have it plugged directly in ,It is probably the compressor or overload relay on the compressor. You can bypass the thermostat to see if it is the problem, by first unplugging the device, then removing the wires from the thermostat, and jumping them together. Then plug it in If it still acts the same way the problem is in the compressor or overload relay mounted on the compressor. Sometimes the relay can be purchased and replaced or a hard start might work solve your problem.
Aug 07, 2014 | Marvel 61WCM Luxury 45 Bottle Wine Cooler...
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
I have a Magic Chef beverage cooler, MCBC580DBT, it no longer cools, its a 2007, the power is on, the light and the thermostat work, the compressor does not turn on to cool. I replaced the ptc starter and...
same problem w mine and yes if you take the cover off the inside display you will be able to remove the board mine has a hole burnt in it.unplug harness w red blue and brown wires and jump and jump from brown to red unit will turn on you need a new board
Aug 09, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Subzero 532 fridge is warm/ice on inside back
the stop leak works if its a very small leak only. partial charge is just topping off the freon. would give the stop leak a shot first. about $70 bucks a can.
Jun 08, 2009 | Refrigerators
I have an LG fridge top / freezer bottom which I purchased exactly 3 years ago. The fridge has stopped cooling, although the inside light stays on. Also, the freezer is still working perfectly. Firstly,...
Most LG fridges have a 1 year warranty with some components exteneded, such as the compressor or sealed system repair. Those are usually 5 years or long, depending on the model.
Can you tell me the temp. in your fridge please? I have a strong suspicion that it may just be the thermostat.
Feb 03, 2009 | Refrigerators
Brown goo in top loading washer
I had exactly the same problem a few years ago. I thought it was a leak from an oil seal and had technicians out. The problem was that I used the wrong washing powder. Find out from the manufacturer what washing powder you need to use and use only that.
Dec 21, 2008 | Kenmore 44832 Front Load Washer
Unit not working
could be a thermostat problem, check the thermostat for continuity. it should have, if not, then replace the thermostat.
tnx 4 using fixya,
drcool
Oct 01, 2008 | U-Line 75WC Wine Cooler
replacing leaking evaporator on Sub Zero R134A
Jun 22, 2008 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
98 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
