Question about Dopod 838 Smartphone
Cannot get PDA Smartphone to sync with computer
It was syncing well till 1 May 08. Then computer simply say 'USB Device not reocgnized'. Has checked the connections, cable, USB, Drivers. The fault is with the PDA. What shall I check?
  • woop07 Jun 06, 2008
    yea, i have the same problem. i dont know what to do with it. please help.
My computer simply cannot detect the dopod. Hence cannot sync
Posted on Jun 18, 2008
Delete all your PC registers (e.g. windows PC) inside your dopod. From Dopod Activesync software, you can click menu/options and delete all as advised earlier..
Reset your unit and try connecting up your unit to your PC.
Good luck!...
Tried that loads of times. still have the same prob. it says connected but also a msg pops up, it says communication error with phone or sumthin.
status shown is connected but cannot sync.
Posted on Jun 11, 2008
    Genius:
  • 1,224 Answers
Software you need to install software
let it install before connecting phone to comp
then after finish the install then connect the phone to usb cable
you might if this didnt work the first time have to uninstall all the software and try a fresh copy of the software in comp to sync everything with desktop manager
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
.msi in HTC
Hi. You can download Microsoft ActiveSync through this adress: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/ActiveSync-download.mspx) After you install this software, just plug your PDA into your computer with the USB cable, and run the .msi. After the installation completes within your computer, ActiveSync should run and install the software to your device also. Hope this helps.
May 20, 2009 | HTC Touch P3450 Smartphone
PC Driver
there is no need for drivers for sync u just need active sync installed in WINXP if u dont have active sync install it from www.windowsmobile.com or see if it came with ur mobile in a cd and Windows mobile device centre in WIN VISTA that is bundled in the installation already u just find it by typing in search WMDC or in All programs u can look for it after u launch it just connect ur mobile thru usb cable provided and go in ur mobile pda start>settings>connections>usb connections set ur device for sync not mass storage and then press ok open the active sync software in xp or WMDC in Vista and it will automatically connect ur device then sync ur device as req
pls let me know if i can help u more in this and pls rate fixya if i have fixed ur problem
Feb 25, 2009 | i-mate SP5m Smartphone
How can i transfer the data from the computer to htc toch pro
u have to sync ur contacts u can do it by connecting it thru usb cable provided woth pda and thru active sync create a profile and there u go
Feb 01, 2009 | HTC Touch Dual Slider Smartphone
My device won't sync with pc
What is your device? Windows?
If windows install the Active Sync and then plug the USB for PDA.
PS: Active sync is a Microsoft software to sync PDA with PC!
Dec 22, 2008 | Computers & Internet
Acer n300 wont sync
you also have a connection manager on the PDA Itself ( Active sync ) Try syncing from the PDA as Well As The Computer Active Sync Program.
Also make sure if you have a firewall, you allow the PDA into it as a trusted Device.
Mike @ Compurepair.
1 more thing, try on/off the PDA whilst in sync mode.
Hope This Helps.
Feb 21, 2008 | Acer N300 Pocket PC
PC/PDA "connected" yet PC won't read PDA
try syncing through bluetooth, there could be a problem with the cradle. i have had an issue very similar to yours and had to do a soft reset on my pda. then set up your device to use a blue tooth connection( you may need to buy a bluetooth dongle for your pc).
Feb 06, 2008 | Compaq iPAQ H3850 Pocket PC
Sync problem
I assume you use activesync. Check in the options that it is set to synchronise this data. if you have already done this try reinstalling activesync or installing the newest version, 4.0.
Sep 15, 2005 | Dell Axim X3 Pocket PC
Sync problem
I am assuming you use activesync. Check in the options that it is set to synchronise this data. If you have already done this try reinstalling activesync or installing the newest version, 4.0.
Dopod 838 Smartphone Logo
176 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
