Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica 7030 F-34-1 code
How to reset error code F-34-1 on Konica 7030 printer
  • 3 more comments
  • Carlos Mansilla May 30, 2008
    REPLACED FUSER WITH NEW UNIT ON KONICA 7022 , ERROR F-34-1 STILL APPEARS TRIED RESETTING BUT ERROR STILL PRESENT
  • Anonymous Jun 08, 2008
    Ive got a Konica 7020 I just replaced the heat and pressure rollers and the machines done approx 160,000 copies/prints so its nearing major pull down I think, its coming up with f34-1 so i went into 25 mode reset 3-1 to off and its coming up with f43-4 and still 1? does that mean the thermistor on the left is faulty or not reading temp right or is it the two sensors on the right under the hea roller, been a few years since Ive worked on these, this is one I own and lost my service manual
  • Anonymous Oct 08, 2008
    f-35-_
    Konica 7030 F-35-8 code problem. I d'ont now what's is this problem. Please help me
  • Anonymous Mar 05, 2009
    MY photocopy its not chang what problem????/
  • 6 Answers
Try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
Posted on Aug 09, 2008
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
Konica Copier says malfunction detected code C-0096
this is the error code for the image transfer belt pressure retraction failure to reset error code with the machine turned on open and close the front door if error comes back will have to replace either the transfer belt or the belt pressure motor
Oct 26, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
1,573 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
