Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Problem is side and medium strip in between doors is getting extremely hot and compressor fan was replace by tech and fan ran for 2 minutes and shut off. However when we unplug refrigerator and replug in fan runs for maybe 2 minutes and shut off again and will not restart and refrigerator get hot again. Please advise a solution.
  • 410 Answers
You didnt list a model number but im betting there is a control board beside the compressor that has gone bad not allowing the compressor fan motor to run. if you will list a model number i will gladly help you trouble shoot the control board/.. thx peyton
Posted on Oct 10, 2010
Why does it get very hot around the door's perimeter?
The door is heated so it doesn't stick shut with ice. It may be that the condenser is clogged or the fan isn't running, causing excessive heat in the strip. Clean the condenser thoroughly and check the fan.
Jul 01, 2012 | Kenmore Elite Side By Side Refrigerator -...
I have a 6th sense whirlpool 25.6 cu with water
First , remove the kick plate and make sure the coils are clean of dust . lint , pet hair , etc . Then pull the refrig out and remove the rear lower panel , covering the compressor and cooling fan ( evaporator motor ) . Make sure this motor is working , if the compressor is running . If the fan does not work , then replace it as soon as possible . This fan , cools the coils and the compressor , which if not working , causes the divider strip to become extremely hot , and could cause the compressor to have problems , due to the heat . After removing the rear panel , be sure to re-install it , as this is there , to direct the air flow as needed .
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
CENTER METAL SURFACE THAT DOOR SEALS TOUCH WILL BURN YOUR SKIN
go to partstore buy the part # DA97-01949A and fix it you can put the fan in back refrigerator keep it cool when the part come and fix it
May 11, 2009 | Samsung RS2630SH Side by Side Refrigerator
Cooling Fan is not working automatically
thass as good idea, but instead justreplacethe existing fan ( which is your problem)the fan is no good, so rewiring will not help any. replace the part!
Mar 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Center stip is extremely hot
2 things you neeed to check first of all clean teh coils underneath the refrig. then pull unit from wall and pull off rear compartment cover and see if the fan that cools compressor is running. it is possible the motor is jammed or bad. if the motor is bad you can put a house fan blowing into the comp compartment until you get it repaired.
Jan 30, 2009 | Refrigerators
I have a Kennmore Cold spot Model # 57285791. The center strip where the two doors meet is extremely hot and everything in the freezer is defrosted.
Jan 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
We have a GE Monogram side by side built in ZISB40DM, 48" with dispensor. We are having problems with the compressor heating up and the colling fan to the compressor not going on. Also, when you...
just check the wiring running to the fan and if you can, connect the fan direct to mains to check the fan itself is ok. no fan then the compressor will get hot and cooling will be affected.
the hot strip between the doors is deliberate - it stops condensation
Aug 23, 2008 | Refrigerators
Ge side by side freezer refrigerator
That is called a heat strip. Used to keep moisture down around the door gaskets. You will need to roll unit out, take lower back plate off and check to see that the condinser fan is turning when compressor is on. If not,replace fan motor
Jul 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
