Question about Maytag MDE2600 Electric Dryer
Drum is noisy and takes more time to dry clothes
    President:
  • 2,992 Answers
A common Maytag problem is for the blower fan to come loose on its shaft. This causes the rumbling noise, and since air isn't moving properly it causes the slow drying. It's not difficult to replace the fan, but it requires some patience, some basic tools, and probably an extra set of hands. This site and this one both have helpful information on how to get at the fan, as well as selling parts. You may also be able to find the fan locally if you have an appliance parts store around.
If you don't feel up to tackling the repair yourself, this repair won't cost as much as a new dryer if you call a service technician in. But it's not hard, you'll save some money, and feel good about it if you do it yourself. Good luck, and thanks for using Fixya.
Posted on Oct 07, 2010
I have a kenmore 70 series electric dryer that squeals or squeaks when you start it and will squeak periodically during the drying cycle. From what I can tell the actual model number is 66702692 or 110...
hello there and welcome to fixya
There is several areas that you will want to check and listen to it carefully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 01, 2011 | Kenmore Dryers
When the dryer tumbles, it makes a loud noise. What could it be? How do I fix it?
Go to Sears and purchase a new belt & idler pulley wheel for yours. The bearing in the pulley has dried up bearing causing this noise. The belt will be stretched and replacing it the same time will save a future headache
Dec 27, 2010 | Dryers
My GE dryer is making a real loud noice while drying model #DBXR463ED2WW
hELLO THERE
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 04, 2010 | GE Dryers
Kenmore Series 70 electric dryer 66702692 Dryer makes sluggish sound when hit start button./ Dryer heats up and does dry clothes for up to 5 minutes at best then shuts off. Typically shuts off...
Hello there:
please use this troubleshooting list i have pprovided below to help troubleshoot the problem and let me know how this is going ok
Oct 06, 2010 | Kenmore Dryers
My tumble dryer squeaks really loudly when its going and seems to be taking ages to dry - any idea?
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 27, 2009 | Hotpoint Dryers
Dryer rumbles and vibrates like a bering going out or something, it will still dry a load. the noise comes and goes.
Hi
If your dryer is making noises and vibrates then you'll need to check for the following--
  • Rollers --Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
  • Idler pulley --Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
  • Glides --Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
  • Rear drum bearing --Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
  • Blower wheel --Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Please do rate this solution as Fixya if found helpful and revert for any assistance.
Thanks
Rylee
May 11, 2009 | Hotpoint Dryers
Kenmore stackable washer/dryer...dryer making HORRIBLE shrieking sound while drying...any ideas?  don't have dryer #
Hi
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 18, 2009 | Kenmore 84052 Dryer
Clothes dryer makes alot of noise when spinning....what can cause this...still dries clothes fine
Jul 11, 2008 | Maytag Performa PAV2200
Loud Dry Bearing sound
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Fisher Dishwashers
Maytag MDE2600 Electric Dryer Logo
59 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
