Question about General Electric WD21X10187 MODULE CONTROL ASM
GE PDW9880J0S, ASM Control Module WD21X10187, replaced with the new one, dish washer will not start. On the key pad everything working, advise
  • amrits Oct 07, 2010
    There is nothing to re seton the Module
    I do not know how to reset, only push botton on the control panel is start/reset, it was done, still DW do not start
  • 11,896 Answers
Have you tried resetting the machine? Have you tested the control board to see if there is information sent to each component including the module?
Posted on Oct 07, 2010
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Oct 07, 2010
    I meant did you reset the stove after you installed the new module?
  • Nate Stansfield
    Have you checked the door switch?
  • Nate Stansfield
    Symptom
    Check
    Click on underlined items for further information
    Dishwasher does not work - no sound, water or lights
    Check for a blown fuse or tripped circuit breaker
    Check that the dishwasher is plugged in securely
    or
    Inspect the wiring connection to the dishwasher for burns or breaks.
    Check the door latch
    Test the door switch
    Test the timer motor
    Test the selector switch
    Test the motor start relay
    Test the motor
    Dishwasher does not start but motor hums
    Unjam the motor
    Unjam the pump
    Test the motor
    Check the drive belt
    Dishwasher does not fill with water or it drains while filling
    Check that the water supply is turned on. The valve may be located under the sink.
    Inspect the float assembly
    Inspect the fill tube for kinks
    Test the float switch
    Check the inlet valve filter screens
    Test the water inlet valve
    Test the drain valve lever arm
    Check the drain valve
    Water does not drain from the dishwasher
    Check sink drain and drain hose for restrictions
    Unjam the motor
    Unjam the pump
    If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
    Dishwasher is leaking water
    Inspect the seals for the main tub, float, heating element and blower diffuser
    Check for overfilling
    Inspect the water and drain hoses
    Inspect the door gaskets
    Check the water inlet valve
    Check the pump
    Water or soap leaks around the door
    Make certain that your detergent is intended for dishwashers. Do not use liquid dish soap.
    Inspect the door seal gasket
    Inspect the door hinges
    Inspect the spray arms for damage
    Water drains through the air gap into the sink
    Check the air gap
    Dry cycle problems
    Test the heating element
    Test the drying fan
    Test the thermostat
    Dishwasher is noisy
    Check the spray arm for damage and obstructions
    Check the inlet filter screens
    Check the motor and mounts
    Check the fan motor and blade
    Check the drain for obstructions
    Door drops down with too much force
    Check the door springs
    Door does not close or latch properly
    Check for obstructions
    Dishwasher cycle does not complete
    Test the thermostat
MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Aug 19, 2008 | Maytag Dishwashers
Remote from dish network won't work for sound and off/on... dish says it's my tv because it is old
The Dish Network Remote Key pad nunbers still work?Yes,the remote is the problems,tell Dish to send u a replacement remote.
Mar 14, 2011 | GE 46GW947 46" Rear Projection Television
Installed new control asm on ge washer wbse3120b now all the lights are flashing and no power?
On you old control there was a plug with just a jumper wire. This is the model select plug. Without this plug the washer does not "know" what model it is on and the lights will flash. http://www.appliance-repair-it.com/ge-washer-lights-blink-after-replacing-the-control-board.html
Sep 13, 2010 | GE WBSE3120B Top Load Washer
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Maytag neptune key pad ocassional working
The machine control pad, with the LED lights, is going out. Replace this control pad and all lights should be working normally again.
Jul 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 03, 2009 | GE Ovens
Control panel for GE microwave
The control panel module is different from the membrane. Unfortunately these modules themselves are usually very expensive, perhaps 1/2 the cost of a new microwave.
Sorry.
Oct 06, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Jul 19, 2009 | Whirlpool Washing Machines
Have to hit start button several times over first few minutes, due to it shutting off. I think it may be a faulty switch?
I have the exact same problem.. (I suggested I'm going to replace the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303) found one for $45 at partadvantage.com
Nov 15, 2007 | GE WBSE3120B Top Load Washer
General Electric WD21X10187 MODULE CONTROL ASM Logo
216 people viewed this question
Top General Electric Dishwashers Experts
Tom
gbob59
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
