Question about Dewalt Drywall Screw Setter 50 Pk Part No. DW2014B
How to replace drywall bit - Dewalt Drywall Screw Setter 50 Pk Part No. DW2014B
    Champion:
  • 248 Answers
Should be able to unscrew and remove plastic head, and pull out bit by hand
Posted on Oct 09, 2010
How can I fix tile backer to honeycombed drywall
Get you some heavy duty liquid nail or similar adhesive, put it in strings/loops, wait a bit, put rock on, hold a bit done
Mar 15, 2015 | Drywall
Drying out wet drywall
I'm assuming your talking about drywall that was wet during a flood of some type? Recommend you remove all damaged drywall and using a straight edge and a utility knife this can be easily accomplished. After you cut and remove the damage, remove all screws or nails from the studs giving a good surface for the new drywall that your going to replace the damaged stuff with. Get that done and we can move onto taping and drywall compound repairs. Hope this helps.
Mar 16, 2014 | Tools & Hardware - Others
When using the drywall screwgun the drill bit comes out and sticks in the screw after every time I drive in a screw. Why doesn't the bit stay in place in the drill? Why does it come out and stick to...
Because the tip is brand new or you don't have a magnetic ti. Try tilting the gun a little sideways before you pull it away from the screw. Sorta like tilting a sweating glass a little bit before you lift it off of a coaster so that the coaster doesn't stick to the bottom of the glass.
Jim
Jul 26, 2011 | Bosch SG45 4500 Rpm Drywall Screwgun
Hi, my hitachi drywall gun runs good but the bit dosent spin, it dont screw. any idea. thanks
drywall guns wont spin until you put pressure on the tip, load a screw and put it to the wall (or whatever) add pressure and pull the trigger
May 08, 2011 | Hitachi W6V4 4500 Rpm DryWall Screw Driver
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
Was given a drywall screw gun to use, but I need to change the bit to fit smaller star drywall screws. How do I remove and replace this screw bit?
I use a DeWalt and the bit should just pull off like you would a cordless drill/driver. You might need a little persuasion (vice grips or pliers) because of the constant torque placed on it.
Mar 02, 2010 | Drills
Need to know how to operate milwaukee screw gun?
I hope you're talking screw gun and not drill/driver. Screw gun used specifically to set screws in drywall. Make sure you have proper tip in gun (usually #2 phillips). There should be a rotating collar on the gun to control screw depth. The screw should only "dimple" the drywall. It should not tear the paper but should be below the plane of the drywall. To check depth run a putty knife over the screw heads. If you hear it hit, screws need to go a bit deeper. To work quickly; lock the trigger on and place the screw on the gun. Apply steady pressure and let the screw walk into the board until gun breaks free. Takes a bit of practice but pretty soon you'll be flying.
Mar 02, 2010 | Milwaukee Tool Drills
Trying to mount blinds in kitchen, walls plaster over carstone. as soon as we hit carstone masonry drill stopped in its tracks!! less than half inch into wall!! really need to be at least quarter inch...
Is there a space between the back of the drywall and the stone? Or is the drywall tight to the stone? Either way, you need a masonry bit, I hope you have one, a hammer drill would be real nice, but you can muscle through it without one. You can try a smaller bit as your first cut , then go to the next size. Makes it a lot easier to drill. If there was a space behind the drywall, they make all kinds of fasteners for drywall only, they will hold quite a bit, but might not be enough for blinds that are going to be yanked on.
Feb 13, 2010 | Black & Decker Drills
How does the adjustable depth drywall bit work? The bit inside keeps spinning and does not drive screw into sheetrock?
It's not the tip, but the screw gun itself. The screw gun has a clutch on it that allows you to set the screw at different depths. You must adjust the screw gun to the desired depth. The deeper you want the screw to go, the less the clutch will slip.
Jim
Jan 03, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
Bosch sg 45 drywall screw gun
You have to replace the entire depth guage assembly (the front plastic pieces where the bit driver is). Unfortunatly Bosch does not make the individual pieces for this gun. Any Bosch service center will be able to supply you with this piece
Apr 10, 2009 | Bosch SG45 4500 Rpm Drywall Screwgun
Dewalt Drywall Screw Setter 50 Pk Part No. DW2014B Logo
637 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
