Question about Honeywell Heating & Cooling
My honeywell smartfit thermostat T8677B1006 is showing what I believe is an error. It displays F:04 on the readout is there a way to reset my thermostat?
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: honeywell thermostat
You have lost power to the A/C system. Check that the Emergency switch has not been turned to the off position by mistake. If it is in the on position you will need to inspect the indoor unit to see if an access panel may have opened slightly causing the door safety switch to open and turn power off to the unit. This is typical found where you replace the air filter. If neither of these help, check the circuit breaker box for a tripped breaker. Cycle the breaker for the A/C system and inspect the thermostat to see if it is displaying any information. If still blank, you may have a bad transformer or something else wrong and a technician will have to diagnose. Hope this is helpful.
Posted on Sep 12, 2007
SOURCE: I have a honeywell smartfit
I had exactly the same problem. F4 code says the control valve has jammed --- but it hadn’t.
I ended up having to swap out the room controller and the base unit (I bought the pair since it was winter and I couldn’t ‘eff’ about)
On investigating (well, you have to don’t you?) I could find no obvious fault but did notice that a large electrolytic capacitor was across the actuator motor.
Since these things work by reversing the supply polarity to the motor to drive the actuator one way and the other it strikes me as strange that a polarity sensitive component, one that must be always connecter positive to positive, is used in the way that it is.
Bottom line, tough luck, mate. Replace the units.
Posted on Jul 31, 2008
T8677B1006 has no display
Without knowing the furnace type, it's hard to say if yours has a fuse (automobile type) on the furnace board that's bad or the low voltage transformer on the furnace is bad.
May 19, 2015 | Honeywell Programmable Thermostat Heater
Display has gone off T8677B1006
Try replacing the batteries, if that does not work replace the thermostat.
Ive currently got a honeywell smartfit thermostat control which is displaying F24 which ive been told means i need to replace the control panel, again!! ive already replaced it once not so long ago (approx...
There are other universal replacements but if it was me I would stick with the honeywell parts. I know they are more expensive but in your instance where you already have a problem that is causing the control panels to fail I'm afraid you would make it worse by using other then factory replacements.Thank you
May 17, 2011 | Honeywell Heating & Cooling
My honeywell smartfit central heating control panel show the following; ''OFF'' and I can not turn it on no matter what butten I press. I tried to turn it on by the user guide . (main power is on in the...
Hello my name is Heath it will be my pleasure to assist you. The first thing you need to do is move the slider to the auto or once or cont position this should turn the system on.
May 01, 2010 | Honeywell Programmable Thermostat Heater
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
348 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
