Question about Kwikset 909 909-L03 Lifetime Polished Brass Smart Code SmartCode Signature
Replacing door handles and the "eschosions?" are not screwed on how do you remove
  • 963 Answers
Installation instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Kwikset has a one year warranty protecting the electronics and covers mechanical function and finish for the lifetime of the lock.
This link includes the info and contact information:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Posted on Nov 09, 2011
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Mazda Mpv replace door handle
Most doors have a main screw that hold the handle that pulls the door shut screwed to the frame behind it. Look for little removable trim pieces. Check behind the inside door latch for two screws. Need to remove the power window switch panel, and connector. Check for screws on the side of door panel. The rest are push pins that should pop out when you pull the door panel out. If you have a door light, be sure to reach behind and remove connector before removing the panel all the way.
May 27, 2013 | Cars & Trucks
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
Replace outside door handle
you need to remove the inside door panel first. there will be a screw at the inside door handle and two screws for the armrest in the center of the panel. look around the outside edges of the panel for any other screws or clips to remove. the rest of the clips are behind the panel and snap when you pull on the panel. once off with the window up you can see the door handle screws. two of them. remove the connecting rods first.depending on which door you may have a lock rod also. then remove the screws and the handle will come out. good luck
May 22, 2010 | 1998 Toyota Corolla
I want to replace the driver's side mirror and need to remove the inside door panel thanks
here is step by step instruction to remove your door panel. i am not sure if the picture are coming through so please forgive me on the images. please do not forget to rate and comment about your experience today wih fixya Front Door
  1. On vehicles without power windows, place a soft cloth under the window regulator handle and pull upwards on the cloth to release the snapring. Remove the regulator handle and plate.
89550p12.gif Using a taped prytool, carefully remove the bezel portion of the handle
89550p14.gif Remove the bezel by pulling towards the tip of the handle
89550p15.gif Remove any screw covers ...
89550p16.gif ... and extract any retaining screws from the door panel
  1. Remove the screw from the inside handle and slide the handle forward. Disconnect and remove the handle from the control link.
  2. On manual mirrors, remove the setting screw and knob. Tape the end of a thin flat-bladed tool and pry the retainer loose to remove the cover.
  3. If equipped with power windows, remove the power window switch from the and armrest.
  4. Remove the mounting screws and remove the armrest from the door panel. Remove the inside door handle bezel by pushing rearward.
89550p18.gif Carefully pry the edge of the door panel around the outer edges, then remove the door panel
89550p13.gif Once the door panel is removed, make sure to disconnect all wiring
  1. Remove the door courtesy light by pulling outward. Disconnect the electrical wiring.
  2. Remove the two screw caps and speaker cover(s). Remove six screws from the trim panel.
  3. Remove the door pocket from the panel.
  4. Tape the end of a thin bladed tool, then insert the tool between the door panel and door and pry the panel outward. Disconnect the electrical wiring after the panel is free and remove the panel from the vehicle.
To install:
  1. Connect the electrical wiring, if equipped, and install the trim panel onto the door.
  2. Secure the trim panel with the mounting screws, then install screw caps and speaker cover(s).
  3. Install the door pocket.
  4. Install the armrest and secure with the mounting screws. Install the power window switch as required.
  5. Install the door courtesy lamp. Install the inside handle bezel.
  6. Install the outside rear view mirror cover and retainer.
  7. Connect the inside handle to the control link. Install the handle, slide it rearward and install the screw.
  8. With the door window fully closed, install the window regulator and handle.
Apr 17, 2009 | 1993 Toyota Camry V6
Rear door actuator is making a noise, needs replacing
Snap out two door pull strap retainer screw covers. Remove screws.
Remove one screw from lower rear door panel.
Remove screw retaining rear inside door handle cup . Remove rear door inside handle cup.
Using a Trim Pad Removing Tool pry trim panel retaining clips from rear door inner panel.
Feb 12, 2009 | 1995 Mercury Grand Marquis
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Kwikset 909  909-L03 Lifetime Polished Brass Smart Code SmartCode Signature Logo
126 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
