Question about Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
I appreciate your help. I have a Qosmio and the power led is flashing yellow even with the power cord connected and the power button is off (not blue, or anything else) any ideas.. Thanks..
    Novelist:
  • 77 Answers
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
Posted on Jun 08, 2008
QOSMIO G30 no start up only flashing DC-IN LED
Rebouldin resoldering the video proccesor this is the problem or change the main bord a new !
Feb 06, 2014 | Toshiba Computers & Internet
Qosmio G30 No start up Flashing DC-In LED
Yuo have a trouble in the main video bord change it or make a rebouling soldering to the video proccesor this is the solution
Toshiba Qosmio G30 Flashing DC- In LED on power up and cannot start laptop
I found some G30 with defective memory and it cause boot up problem. You can try to remove one memory to test it. Testing the laptop with a good working memory is the best way.
Feb 06, 2014 | Toshiba Qosmio G30-166 Laptop AC Power...
I have a Toshiba Qosmio X870-BT3G23 and it will not turn on when i plug it in the charger light is red instead of normally yellow
Consider a new battery. How old is it? A battery has a Cycle Life, when it's reached it's time to replace it. If so, always replace with a genuine replacement, some aftermarket batteries don't work well at best, and COULD be a Fire hazard at worst. You could try a different Cord/Charger with the EXACT same power specs as the original.
Apr 20, 2013 | Toshiba Qosmio X870-BT3G23 Customizable :...
I have a toshiba qosmio laptop that stopped working all of a sudden. The problem is it will not start up. What I noticed is that that the power indicator lights on the front that are usually green are...
remove the battery and see if it works fine, use only the power supply. If it works the problem is the battery if not you need to test your power supply. That's the easier way
May 04, 2012 | Toshiba Qosmio F25-AV205 Notebook
Toshiba qosmio f50 power button flash no startup
You have to put back the same 8 gB kingston flash drive for the operating system.
Apr 08, 2012 | Toshiba Computers & Internet
Tosibha qosmio f15 av201 does not turn on when power button pressed
i am no whizz, but i think, just THINK maybe you should get some friend or relative to check the wiring to the fan and the power button, maybe when cleaning the fan, the wires were losen, as the button is millimeters away from the fan.
i hope it might help, if not i already said, i'm no whizz
Aug 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba QOSMIO F15-AV201 Notebook Logo
1,638 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
