Question about Kenmore 24032\24036 Top Load Washer
My washer is leaking from the seal at the bottom of the agitator
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's. If the problem is the gasket, Sears has replacements for about $10.
First, pull the cabinet.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Oct 07, 2010
Maytag washer 9501EWW leaking only when agitating
Could be shaft seal at the agitator top or there is a seal at the bottom that may leak from the agitation vibration. There are several online appliance parts sites that will help with diagnosis and repair parts.
Apr 13, 2015 | Maytag Washing Machines
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
Oil in the bottom of washer
The oil is leaking out of the agitator gearbox. The water is coming from the seal on the agitator. I think the gears are badly worn..
Nov 19, 2013 | GE Washing Machines
Maytag Washer noisy & leaks lots of water from bottom of machine
the drum bearing are damaged due to water leak from seal inside the drum. that's why water on the floor. silicone paste mo use as it has other major problem.
Nov 02, 2009 | Maytag Washing Machines
Washer is leaking around bottom of the drum.
Yes, this does sound like the seal is bad. Unless you have replaced the bearing and seal in one of these bafore. It can be very dificult, without expierence. If not replaced correctly, it can still leak or can cause other problems.
Nov 14, 2008 | Washing Machines
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Water leaking where motor goes into the drum
there is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
May 22, 2008 | GE WHRE5260E Top Load Washer
Amana washer
PULL,PULL. turn your head and pull!!!!!!!!!, your also gonna need some adhesive for that seal kit silicone wont work
Feb 24, 2008 | Washing Machines
HELP!! Leaks!! Leaks!!!
the inner tub and outer tub has a seal under the agitator. this must be replaced. use a spanner or a large channel lock plier to remove the nut. seal is underneath it.
Sep 04, 2007 | Frigidaire GLWS1233A Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
