Question about Remington MB-70 Beard Trimmer
The battery on my Remington MB70 trimmer is no longer hold a charge. Can the battery be changed to perhaps an Li-ion variety?
  • Remington Master
  • 1,624 Answers
The charging system in your trimmer is not designed for lithium ion batteries. Installing a lithium ion battery could cause fire and/or personal injury. You should always use the same type battery that came in the shaver originally
Posted on Oct 08, 2010
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Are all the Lithium batteries working like this. Mine work for a short time then stop dead. Wait a while then they will work again. Really a pain when you are working trying to do somthing and have to run...
I use the Ryobi Li-Ion tools the L-I batteries will cut off when they get to a low charge level this is to protect the batteries Li-Ion batteries life span is shortened when fullt discharged so when the tool suddenly stops put the battery on charge,also if the battery has a charge indicator light for a more accurite idea of the charge (green is charged,red discharged) hold the test button on then run the tool the light may go from green to red if it does that shows the the charge is about depleted if the light stays green you have a little run time left.
Oct 25, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I just purchased a power shot (SD 1300 IS), right before Christmas 2010.. It won't turn on it says change the battery pack? Is the battery already bad? If so, why?
If this battery is a Li-ion then when it runs down it may lock itself out. Li-ion batteries start loosing their ability to hold a charge just as soon as they are manufactured. If this camera sat on the shelf for a year, then the battery is dead and perhaps you can recharge it. If these are carbon zinc, or akaline, and they sat on the shelf in the camera, then they are surly dead.
Feb 05, 2011 | Canon PowerShot SD1300 IS IXUS 105...
MP4 player will not hold charge
If your MP4 player is 'old' or frequently used and you can use it while being connected to your PC or charger, then the most likely reason is that the internal Li-Ion battery is worned and not capable of holding a decent charge: the solution is to replace the internal Li-ion battery: you have to decide if this is economically viable especially if you cannot do it yourself or the replacement battery is too expensive.
Dec 19, 2009 | Kenwood Audio Players & Recorders
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Remington MB-70 Beard Trimmer Logo
743 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
